Author Topic: Cumulus on Computer - Security  (Read 1408 times)
Offline Aussiebritt
« on: December 08, 2024, 03:31:35 PM »
I need a solution for a computer running Cumulus which needs to stay on 24/7 for reporting with no data lapses. I’m concerned with security on a machine on 24/7. Are there workarounds to that?
Offline R.Sidetrack
Re: Cumulus on Computer - Security
« Reply #1 on: December 08, 2024, 04:30:30 PM »
Presumably the Cumulus machine is inside your local network. So your primary defense should be the firewall between your internal network and the internet.
That firewall can take many forms, but for many the  firewall is built into the gateway/modem/router that your internet provider typically bundles into your monthly bill. Of course, you can add additional systems behind that bundled box.
One thing you could do is run CumulusMX on a Linux box. Of course, Linux boxes can be hacked too, but the odds are that Windows boxes are a more likely hacker target.  And, there is a pre-built CumulusMX 'image' for a Raspberry Pi (linux) available, which makes it a bit easier to install.
« Last Edit: December 10, 2024, 10:51:46 AM by R.Sidetrack »
Graham
--- Variety of 'discrete' Ecowitt devices; CumulusMX on Raspberry Pi4 ---
Offline WxFox
  • Northern Androscoggin Weather
  • Happiness is having my toes in the warm sand.
    • Northern Androscoggin County Weather
« Reply #2 on: December 08, 2024, 05:40:55 PM »
I use old Cumulus, version 1.9.4 and it's been running for about 20 years and I've never had any trouble and I don't expect to. It runs on a separate computer by itself, as my main computer uses Linux. The old original version 1.9.4 does not run on Linux.
Davis VP2 (cabled) Uploading to PWS, Weather Underground, Weathercloud, WOW, WeatherBug, AWEKAS and Twitter, using Cumulus.  Cabled = fewer problems, less maintenance and better reliability!
Northern Androscoggin Weather:
http://home.myfairpoint.net/~jody2011/index.php
Mobile friendly: http://home.myfairpoint.net/~jody2011//iCumulus/#_home
CWOP AV346
Offline box
« Reply #3 on: December 09, 2024, 02:01:19 PM »
I am running  Linux cmx on a Synology NAS, that takes care of security and low power consumption
