Author Topic: ftp issues WD & Cumulus  (Read 4244 times)
Offline NorCal_Dan
    • Traveling RV Wx
« on: June 02, 2024, 08:16:32 AM »
Not exactly sure what my issue seems to be telling me.  Running WD & Cumulus on the same computer both using my Tempest station for data.  If I run either WD or Cumulus by itself then no issue.  But if I run both at the same time I have problems.  Screen shot attached.  Appears to be a conflict with ftp so I'm looking for a solution/idea to allow both programs to run on the same computer.  Is there a difference between ftp and realtimeftp processes?
I'm fairly sure Tempest data comes from the WxFlow servers...and my websites are hosted on different servers...so the only conclusion I can come up with is the ftp process on the computer can only be used by one program at a time.  So is it possible to have WD & Cumulus sleep and just wake up, send data, then go back to sleep?  Or will Win10 "lock" the ftp process so the program that owns it will have access when needed?
Offline weatherbee
    • Sherman Ct. Weather
Re: ftp issues WD & Cumulus
« Reply #1 on: June 02, 2024, 10:00:28 AM »
I'm not sure what the problem is but it can be done.  I'm running on Windows 11.
I'm running WD and Cumulus on the same computer.  I upload both to one server without any problems.
I do use the php upload option in Cumulus instead of the ftp upload.
Tom.
Offline mcrossley
    • Wilmslow Astro
« Reply #2 on: June 02, 2024, 10:40:49 AM »
It could be your hosting company only allows a few concurrent FTP connections? Cumulus uses two.
Offline NorCal_Dan
    • Traveling RV Wx
« Reply #3 on: June 02, 2024, 06:57:20 PM »
Tom.
I think the php upload is working...fingers crossed.  Thanks for the idea.
Dan
