Note: trouble with registration? See this for more info.
1.3mm, centre pin+ would be about right. Also if being used in the ISS then the jack is best to be a 90 degree or if straight then very short with no cable restraint, mostly just use the jack, throw away the screw on plastic cover and heat shrink
Davis have a support article published regarding external battery:https://support.davisinstruments.com/article/wll7jix28j-can-i-power-my-weather-station-iss-with-an-ac-power-source-faqhttp://"You would unplug the solar and remove the battery. Then plug the power adapter into port 2 below"Has anyone tested if it is also works to have all three (external battery, solar power and internal battery) connected?
Quote from: GW400 on March 15, 2021, 08:33:46 AMDavis have a support article published regarding external battery:https://support.davisinstruments.com/article/wll7jix28j-can-i-power-my-weather-station-iss-with-an-ac-power-source-faqhttp://"You would unplug the solar and remove the battery. Then plug the power adapter into port 2 below"Has anyone tested if it is also works to have all three (external battery, solar power and internal battery) connected?I have AC, battery and supercap connected and no issues. However, Supercap does not seem to charge without the solar panel. The CR123A I think would make sense to keep, because if the mains power goes out you still got something that can transmit if your circuit to the station fails, or everything fails and you have your console on battery backup or something.
