Author Topic: Remote Battery  (Read 5454 times)
Online Mattk
Re: Remote Battery
« Reply #100 on: February 20, 2021, 06:02:20 AM »
Just stating the facts  :grin:
And of course 6.2v won't do any damage, Davis's own gear puts out 6.8 volts.
Not real sure why 7.5v was even raised relative to the question?
« Last Edit: February 20, 2021, 06:09:58 AM by Mattk »
Offline azchrisf
Re: Remote Battery
« Reply #101 on: February 25, 2021, 02:03:45 PM »
1.3mm, centre pin+ would be about right. Also if being used in the ISS then the jack is best to be a 90 degree or if straight then very short with no cable restraint, mostly just use the jack, throw away the screw on plastic cover and heat shrink
Actually it's  a 3.5x1.3mm plug. I just got done doing an AC conversion.
https://www.amazon.com/gp/product/B081TYG48P/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
« Last Edit: February 25, 2021, 02:06:07 PM by azchrisf »
Also doing Soil and Leaf 4x
Offline GW400
    • Aadneram Fjellgrend
Re: Remote Battery
« Reply #102 on: March 15, 2021, 08:33:46 AM »
Davis have a support article published regarding external battery:
https://support.davisinstruments.com/article/wll7jix28j-can-i-power-my-weather-station-iss-with-an-ac-power-source-faq
http://
"You would unplug the solar and remove the battery. Then plug the power adapter into port 2 below"
Has anyone tested if it is also works to have all three (external battery, solar power and internal battery) connected?
Offline azchrisf
Re: Remote Battery
« Reply #103 on: March 15, 2021, 11:04:30 AM »
http://
I have AC, battery and supercap connected and no issues. However, Supercap does not seem to charge without the solar panel. The CR123A I think would make sense to keep, because if the mains power goes out you still got something that can transmit if your circuit to the station fails, or everything fails and you have your console on battery backup or something.
Offline GW400
Re: Remote Battery
« Reply #104 on: March 15, 2021, 11:24:16 AM »
http://
Thank you!
That was good to hear. I was also worried about having only one power source in case of outage on the grid.
May I ask what voltage are you delivering to power jack on PCB?
Offline azchrisf
Re: Remote Battery
« Reply #105 on: March 15, 2021, 11:31:02 AM »
5.5 volts DC
The jack is spec'd for 3.3-6V IIRC, same as the Davis power brick for the console.
Tip is positive on the jack.
« Last Edit: March 15, 2021, 11:32:47 AM by azchrisf »
