Author Topic: Cloudheight graph meteohub  (Read 769 times)
Offline Nisse
« on: April 23, 2019, 08:37:01 AM »
Hi!
Is it possible to get a graph of the cloudheight with meteohub?
Offline docbee
  • Moderator
    • smartbedded
Re: Cloudheight graph meteohub
« Reply #1 on: May 11, 2019, 04:05:26 AM »
Can you provide a formula to compute this?
Offline Nisse
« Reply #2 on: May 12, 2019, 02:28:27 PM »
No!
Offline Nisse
« Reply #4 on: May 13, 2019, 04:03:49 AM »
I dont want to calculate the cludbaseheight with a formula, that value I already have.
I want to get a graph of the values. X-axis is the height and y-axis is the time.
Offline d_l
  • Slide Mtn - Mt Rose
« Reply #5 on: January 23, 2020, 05:08:43 PM »
You mean like this graph?: https://www.tceweather.com/cloudbase_graph.html  although it has X-axis as time and Y-axis as height.
You should set up a Meteohub virtual sensor to generate input data for a graph.  See this how-to explanation: https://forum.meteohub.de/viewtopic.php?f=9&t=14621 .  It describes plottable cloud base heights calculated by a virtual sensor.
BTW, thanks for this idea of cloud height graphs out of the Meteohub.
Edit: The cloud base height over time looks a lot like the Chandler Burning Index when graphed (except when the cloud height is above about 10k ft, the CBI hits the 100 cap and then flatlines over time). Both use T and RH (indirectly for cloud base), so that would be expected.
« Last Edit: February 02, 2020, 12:53:13 PM by d_l »
--Dave--
Offline Nisse
« Reply #6 on: February 04, 2020, 06:42:16 AM »
Exactly, that what I mean.
And I got it work also.
Thanks a lot!
