Jerry, the wall wart problem extended to a Rainwise Oracle III display I had, so even though the run cool, those cheap switching supplies are an annoyance in not failing outright but just getting lower voltage or such output, which are hard to test under no load.
A friend of mine (now celebrating his 91st birthday) fixed old TVs (you know the ones with tubes and all) with his dad when he was a kid and into the time when tube sets were finally eliminated) along with rebuilding classic (Collins, and other higher end ham gear) radios.
His wife, patient wise soul, always could hear some frustration when things didn't work and would go by the shop and say, "First, check the fuse..."
It was amazing as to how often that sage advice for even an experienced troubleshooter (one hand in the pocket when reaching into a TV) needed reminding of the basics.
As to the HIK camera itself, I don't think it is the power supply (yet). I recalled that the Sea Monkey browser would read some older Java files, and linked to the camera with that. It displayed a picture! And in the right lower corner in big block letters the word HACKED was superimposed on the screen.
Paul, with your clue, when I get to the Sea Monkey computer I'll try those two passwords.
Almost all the other resets require sending a file to HIK and getting a file back to load into the camera to reset it.
I don't know if they even do that anymore, and that's why I was hoping to find the kludge that allowed one to reset the camera from within the firewall (somewhat safer I guess) so when they discontinue support or go out of business, we'd not be left high and dry.
Thx for the info so far, and I appreciate keeping these old rigs going
Oh, Mike, if you are in the area and wish to clamor up into my garage rafters to reach the plug in for the camera power supply while I dangle from the roof to try to hold the little reset button in, I'm game for that! Now that you related your pretty good memory of how to do it, I think I read that in the manual at one time and know a lot of disconnecting would be necessary to do the hard, physical reset.
Dale
73
