Make a DHCP IP address reservation at your router.
Because doing so will prevent the IP address from ever changing. That way you'll always be able to find the camera on the local network. Also later on if you decide on accessing the camera remotely it will be important that the IP address doesn't change, otherwise it breaks the port forwarding.
