Author Topic: anemometer (wind vane) stuck on N  (Read 553 times)
Offline petec2
    • Glynsk, Connemara, Co.Galway, Ireland
« on: August 02, 2020, 02:13:36 PM »
i replaced my anemometer in october 2018 and whilst the wind speed looks ok the readings from the wind vane are stuck on N. as it was expensive (!) i hope it isn't toast?
any hints before i climb up to it?
thanks
pete
Offline ConligWX
  • #conligwx
    • conligwx.org
Re: anemometer (wind vane) stuck on N
« Reply #1 on: August 02, 2020, 02:30:24 PM »
Hi there,
not sure whats going on it you have replace it already and in such short time its failed again.
Prodata has a bit about vpro2 wind vanes here:
https://www.manula.com/manuals/pws/davis-kb/1/en/topic/wind-issues
Regards Simon
Offline petec2
« Reply #2 on: August 02, 2020, 04:16:29 PM »
thanks. i saw:
On VP2 systems, cable damage involving the direction conductor will cause the direction to show North, either constantly or, with intermittent wire contact, from time to time;
Any other direction issue usually involves a faulty direction potentiometer in the VP2 anemometer or faulty solid-state direction sensor in the Vue ISS. There is typically no fix for this other than a new VP2 6410 anemometer or Vue ISS
i hope that something that cost nearly 200 euro isn't that rubbish!
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #3 on: August 02, 2020, 04:39:13 PM »
the Wind Speed / bearing is replaceable but not the Wind Direction bearing unfortunately.  does seem strange yours has failed so soon, unless its been inadvertently damaged.  cheapest I have seen is £150 here in the UK.
Regards Simon
Offline petec2
« Reply #4 on: August 03, 2020, 06:51:37 AM »
Thanks. I climbed up to it. The connections and wireless transmitter box are ok. Clean and dry inside. However the vane felt ‘gritty’ when swivelling. I took it off and sprayed a bit of WD40 in and then put it back on. For now it is reading correctly. If I’ve wrecked it too bad as it’s out of warranty. Expected a bit better of something so expensive. See what happens
