Author Topic: Soil Temperature & Water Temperature Sensor Pictures  (Read 2983 times)
Offline kenthcwx
    • Twitter Account
« on: August 27, 2020, 05:34:51 AM »
I contacted Lucy concerning information about the upcoming soil temperature sensor & received this response:
Hi Jamie,
Thanks for contacting.:)
Here's the price and picture information:
Soil temp sensor: 20.4USD/unit without shipping cost included
Water temp sensor: 19.6USD/unit without shipping cost included
Best Regards,
Lucy
I thought the soil temperature sensor was called WH34 but by the looks it's WN31?
The soil temperature sensor does look about 4 inches long but I may inquire about the exact height soon.
Froggit WH4000
MeteoShield Professional
Ecowitt WH32-EP
Ecowitt WH51
Ecowitt WH40
Ecowitt WN30
Ecowitt GW1000
Offline Mandrake
Re: Soil Temperature & Water Temperature Sensor Pictures
« Reply #1 on: August 27, 2020, 05:55:07 AM »
I'll be testing these both when available and will pass on my findings as allowed.
G1ZFO
Ecowitt GW2000 (Test)
Ecowitt WS90 Wittboy - Test
Ecowitt WH41 PM2.5 AQM Sensor
Ecowitt WN35 Leaf Moisture
Offline kenthcwx
    • Twitter Account
« Reply #2 on: August 27, 2020, 06:11:17 AM »
I look forward to your findings. I plan on getting the soil temperature sensor so it'll be interesting as to how well they work.
Froggit WH4000
Ecowitt WH32-EP
Ecowitt WH51
Ecowitt WH40
Ecowitt WN30
Ecowitt GW1000
Offline kenthcwx
    • Twitter Account
« Reply #3 on: August 28, 2020, 05:25:34 AM »
I've had a response back from Lucy, full of information:
The length of the soil probe is 30 cm.
The length of the water temp cable is 3 m.
Model names:
Soil temp sensor - WN34AS(868MHz)/WN34BS(915MHz)/WN34CS(433MHz)
Water temp sensor -  WN34AL(868MHz)/WN34BL(915MHz)/WN34CL(433MHz)
« Last Edit: August 28, 2020, 05:27:21 AM by kenthcwx »
Froggit WH4000
Ecowitt WH32-EP
Ecowitt WH51
Ecowitt WH40
Ecowitt WN30
Ecowitt GW1000
Online olicat
    • FOSHKplugin
« Reply #4 on: August 28, 2020, 06:02:47 AM »
Hi!
In the pictures above it looks like the soil probe can be screwed on.
The water sensor seems to be missing a connector - the cable seems to be connected directly to the PCB.
Can anybody confirm this?
That would be pretty stupid, it prevents the exchange of soil probe for water sensor.
Oliver
Offline e92M3
« Reply #5 on: September 02, 2020, 12:15:04 PM »
Hi
Any updates on these especially on the soil probe re:ETA of availability? I may have missed it, but was it noted somewhere if the (soil) probe can be left in the ground outdoors year-round? I'm not sure but my the looks of it it's not IP-rated. Maybe a protective cover over it to protect it from the elements.
This will be perfect for the lawn (and garden).  =D>
« Last Edit: September 02, 2020, 12:20:55 PM by e92M3 »
Offline Mandrake
« Reply #6 on: September 03, 2020, 09:27:55 AM »
The body of the WN34 is IP rated and the water probe or the soil probe attach to a common body.
I am not sure what the delays are but hope to have some test samples soon.
Will update when I know my devices are on route.
Ecowitt seem to be pretty busy right now.
G1ZFO
Offline tree311
« Reply #7 on: February 09, 2021, 06:39:21 PM »
Checking up on this ... Looking for a soil temperature sensor.
Offline Mandrake
« Reply #8 on: February 10, 2021, 06:34:08 AM »
I've asked if there is any progress.
Last I heard earlier in the year was that they were having some trouble with the IPX rating (i.e. ensuring that the casings stayed water resistant)
Obviously that's a fairly important factor in a external sensor so we will need to be patient for this to be concluded satisfactorily.
When I know more I will update here.
G1ZFO
Offline Tangmu
« Reply #9 on: February 18, 2021, 07:28:34 PM »
That's interesting.  In the bottom picture, Lucy has the Chinese symbol for "wood" on her thumb (mu'), formed naturally in her knuckle creases.  木
Wood is one of the 5 elements theory in Chinese philosophy.  (sorry for being totally off-topic)
Offline Mandrake
« Reply #10 on: February 19, 2021, 05:06:02 AM »
Just a follow up, work has been progressing on these sensors and its still hoped to be available next month!
I'll be testing the first production versions so watch this space when I know its on its way!
G1ZFO
Offline Mandrake
« Reply #11 on: March 17, 2021, 06:58:04 AM »
A little more information on the soil and temp sensor.
It really is nearly ready for those keen and waiting!
It is planned to be listed on the website by Easter and I should have a review of both as soon as possible (transit delays permitting).
G1ZFO
Offline Mandrake
« Reply #12 on: March 18, 2021, 06:46:16 AM »
I have the manual for the WH34
It states the following for info
Power: 1x1.5V AA battery(not included)
Sensor type: Epoxy Sealed Thermistor of NTC
Frequency: 433 / 868 / 915 MHz depending on
location (North American: 915 MHz; Europe:
868MHz; Other areas: 433MHz)
Wireless transmitting range: 100M (300feet)
Sensor reporting interval: 77 seconds
Sensing temperature: -40~60 °C(40~140 °F)
Cable sensor length: 3m(10ft)
Probe sensor length: 30cm(11.81inch)
Battery life: 12 months minimum
Waterproof level: IP65
No mention of accuracy so I have asked for that to be clarified
G1ZFO
Online olicat
    • FOSHKplugin
« Reply #13 on: March 18, 2021, 07:06:07 AM »
Hi!
So is the sensor finally called WH34 instead of WN34?
Thanks for all the good news!
Regards, Oliver
Offline Mandrake
« Reply #14 on: March 18, 2021, 07:32:24 AM »
I think we can assume that WH and WN34 are interchangeable.
The manual says WN34
G1ZFO
Offline Gyvate
« Reply #15 on: March 18, 2021, 07:46:02 AM »
According to their (Ecowitt) own latest internal definition - which they don't seem always to follow themselves  :twisted: - or which they still need to get used to - the "N" stands for a weather station/sensor without solar panel.
If you want to apply this to the existing sensors, quite a few would lose their "H" for a "N".
But with the 34 and 35 series they try to be consistent.
Offline Mandrake
« Reply #16 on: March 19, 2021, 08:03:39 AM »
Update from Ecowitt is that the accuracy will be +- 1C for the new sensor
G1ZFO
Offline sdb
« Reply #17 on: April 13, 2021, 05:22:37 PM »
I am interested in the water temperature sensor/probe to use in a pool.  Anyone have an update on this.  I tried to contact Ecowitt but haven't had and answer yet.
Online olicat
    • FOSHKplugin
« Reply #18 on: April 13, 2021, 06:03:42 PM »
Hi!
If you can't wait for the WN34 and need a 868MHz sensor for the pool you could use the Froggit DP30.
Oliver
Offline sdb
« Reply #19 on: April 13, 2021, 07:14:47 PM »
Actually I have a GW1000BU 915 MHz wifi gateway.  I see that there is an 'Ambient Weather WH31P Water Proof Thermometer Probe Sensor' on Amazon which is 915MHz.  Would this work?  If so, how will it appear in the WS View app and on the Ecowitt.net site?
Offline Gyvate
« Reply #20 on: April 14, 2021, 03:33:35 AM »
It will work, as you can see in our matrix !  8-)
https://www.wxforum.net/index.php?topic=40730.0
We have it there as "water temperature sensor multi channel".
I guess Ambient chose the "P" for Pool  ;) - but you can use it anywhere. I use it to check the temperature in my freezer.
And it's just another member of the WH31 family, i.e. there will be max 8 such sensors shown per console.
They/it will show on ecowitt.net as WH31 Chx (x = 1-8), unless you rename it on the tile.
« Last Edit: April 14, 2021, 05:18:11 AM by Gyvate »
Offline Mandrake
« Reply #21 on: April 14, 2021, 04:43:00 AM »
My latest understanding is this should be ready before the end of April. Not clear what the latest issue has been as I was expecting it to be available end of March, perhaps a manufacturing delay.
When its released and I have some samples on the way I will let folks know.
G1ZFO
Offline sdb
« Reply #22 on: April 19, 2021, 12:00:27 PM »
I got a response from Ecowitt.  It will be available 'soon'.  Anyway I used the Ambient sensor and it works fine.  Now I just need to find a place to put it permanently in the pool.
