I observed a phenomenon I cannot explain - maybe someone here has an idea ...
I'm exporting every hour the data captured by MB Pro from my GW1000 on a minute base.
In the files there is most of the time(the export window is one hour) one, sometimes two, gaps of mostly five (sometimes eight) minutes with no data. Two examples below:
2020-05-27,00:06,14.5,61,7.1,1032.0,0.0,0.0,101,0.0, 0.00, , , 17.8, 51, 41, 51, 48
2020-05-27,00:07,,,,1032.0,,,,0.0, 0.00, , , 17.8, 51, , 51, 48
2020-05-27,00:08,,,,,,,,, , , , , , , ,
2020-05-27,00:09,,,,,,,,, , , , , , , ,
2020-05-27,00:10,,,,,,,,, , , , , , , ,
2020-05-27,00:11,,,,,,,,, , , , , , , ,
2020-05-27,00:12,,,,,,,,, , , , , , , ,
2020-05-27,00:13,14.5,62,7.2,1031.9,0.0,0.5,101,0.0, 0.00, , , 17.8, 50, 41, 51, 48
2020-05-27,11:29,20.8,41,7.1,1031.6,0.3,0.5,150,0.0, 813.00, , , 21.1, 41, 42, 52, 46
2020-05-27,11:30,20.8,41,7.1,,0.3,0.5,150,, 813.00, , , , , , ,
2020-05-27,11:31,,,,,,,,, , , , , , , ,
2020-05-27,11:32,,,,,,,,, , , , , , , ,
2020-05-27,11:33,,,,,,,,, , , , , , , ,
2020-05-27,11:34,,,,,,,,, , , , , , , ,
2020-05-27,11:35,,,,,,,,, , , , , , , ,
2020-05-27,11:36,,,,,,,,, , , , , , , ,
2020-05-27,11:37,,,,,,,,, , , , , , , ,
2020-05-27,11:38,,,,,,,,, , , , , , , ,
2020-05-27,11:39,21.2,41,7.2,1031.3,0.0,0.0,85,0.0, 605.67, , , 21.0, 41, 42, 52, 46
2020-05-27,11:40,21.6,40,7.3,1031.5,0.4,3.6,99,0.0, 846.51, , , 21.3, 42, 41, 53, 45
data definition of the export script:
$# date, time, temperature[C], humidity[%], dew point[C], sealevel pressure[hPa], avg wind speed[m/s], gust speed[m/s], winddir, rainfall[mm], Solar [W/m2], PM25(1) [ug/m3], PM25(2), extra-temp1 [°C], extra-hum [%], soil moisture (1) [%], SM2, SM3
[YYYY]-[MM]-[DD],[hh]:[mm],[th0temp-avg.1:],[th0hum-avg.0:],[th0dew-avg.1:],[thb0seapress-avg.1:],[wind0avgwind-avg.1:],[wind0wind-max.1:],[wind0dir-avg.0:],[rain0total-sum.1:], [sol0rad-avg.2:], [air0pm-avg.0:], [air1pm-avg.1:], [th1temp-avg.1:], [th1hum-avg.0:], [th20hum-avg.0:], [th21hum-avg.0:], [th22hum-avg.0:]
Sometimes I observe sort of a degradation in data quality before the gap, i.e. there are no more values for all sensors but only for some.
[the two gaps inside the line , , , before the last 4 values are a systematic error in my opinion - they are the (missing) air quality sensor minute values. I have an open post in the Meteobridge PRO section of the Meteohub forum with about 200 views but no reply regarding this issue. (MB PRO - export and graphic depiction of air quality sensors (air0pm, air1pm) fails).But that's a different thing.]
There is no visible periodicity for the occurrence - sometimes 30 minutes, sometimes more.
Any idea where this comes from ?
Looks as if the logger chokes and initiates a restart. In the systems log visible in the system tab there are no respective messages. (Maybe in some other log file ?)
Rebooting the device doesn't bring any change.
