Author Topic: WifiLogger 1 firmware update failure  (Read 1118 times)
Offline DRoberts
« on: October 17, 2020, 09:47:04 PM »
Firefox web browser
Following update given by Woj
I followed the steps to the final update and I get the message "update failed" restarting
Here is what I have done so far:
Restart wifilogger from system menu
Did hard reboot of console
Verified MD5 hash
Repeated process 3 times and you know what Einstein said about insanity.
Let me know if you need any other details.
Can anyone help.
thx
Offline 92merc
  • BismarckWeather.net
Re: WifiLogger 1 firmware update failure
« Reply #1 on: October 18, 2020, 12:01:24 PM »
What version is it at now?  I thought I read somewhere you can't make the leap from a very old to the very new.  Don't recall the numbers.
Also, give Edge/Chrome or even IE a try.  I've had some really wonky things going on with FF myself lately.  Both with download and file uploads.  I think they may have a bug.
Offline DRoberts
« Reply #2 on: October 18, 2020, 12:20:35 PM »
Current firmware 2.13
Tried IE. No go.
Offline 92merc
« Reply #3 on: October 18, 2020, 02:13:07 PM »
Under Setup and System, can't you just do an update from the UPDATE button?  Just curious...
Offline WiFiLogger
« Reply #4 on: October 19, 2020, 09:24:05 AM »
Tried IE. No go.
Problem is in the name of file. You have quite old firmware. When WiFiLogger2 was released I have change some little things.
Your firmware name of the file should be WiFiLogger2????.bin and you have WiFiLogger_????.bin
Please just add 2 after r and update will pass.
You can also update using update system. If you don't have update button in SETUP -> SYSTEM
then try to open http://WFL_IP/update
there is extreme simple menu to make firmware update.
Offline DRoberts
« Reply #5 on: October 19, 2020, 11:29:32 AM »
Thanks.  Done. Successful. Appreciate it
