Author Topic: WS68 Surgery  (Read 521 times)
Offline box
WS68 Surgery
« on: March 12, 2023, 02:06:08 PM »
My trusty WS68 bit the dust a few weeks ago
I suspect the capacitor, can anyone tell me if repair is a feasible option?
I have replaced with a WS80 but it would be nice to have a comparator if possible
Offline Rover1822
Re: WS68 Surgery
« Reply #1 on: March 12, 2023, 02:10:43 PM »
Can you describe the symptoms, are you receiving nothing from it?, Some sensors on the array? etc...
Also how old is the unit?
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline box
Re: WS68 Surgery
« Reply #2 on: March 12, 2023, 02:20:25 PM »
Two and a half years old, receiving nothing
Offline Gyvate
Re: WS68 Surgery
« Reply #3 on: March 12, 2023, 02:23:35 PM »
nothing even with new batteries means a total failure - otherwise, if it were only the supercapacitor or the solar panel, it should still work and send some sensor data with new batteries.
Offline Rover1822
Re: WS68 Surgery
« Reply #4 on: March 12, 2023, 02:26:41 PM »
I'm guessing you have done the hard reset of the unit, remove batteries, stick unit in dark place (like a box) for like 5 days.?
After that, I would contact support@ecowitt.net.
Based on what they say. sadly, you may have to buy another unit .
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline box
Re: WS68 Surgery
« Reply #5 on: March 12, 2023, 02:30:40 PM »
Yep, now it's down I can have a fiddle with it
Seems to be some moisture inside the sensor above the solar panel, wasn't there when I checked it in October
Offline Rover1822
Re: WS68 Surgery
« Reply #6 on: March 12, 2023, 02:34:16 PM »
Do the hard reset, as I mentioned, don't get froggy and try until at least 5 days with the batteries removed. If it was water ingress, there is a chance it will either 1) dry out or 2) the hard reset will take care of it.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline Gyvate
Re: WS68 Surgery
« Reply #7 on: March 12, 2023, 02:39:13 PM »
if the hard reset after keeping it in a dark, dry and warm place (or cover the solar panel with black tape) as @Rover1822 already suggested doesn't work, I would talk to Ecowitt support.
Ecowitt are just now alpha-testing a new protection for sensors, especially anemometers with challenging exposure (e.g. close to the seaside) against humidity and corrosion.
They may offer you a trial "package" - or/and even exchange your array.
Offline box
Re: WS68 Surgery
« Reply #8 on: March 12, 2023, 03:05:42 PM »
Thanks for the suggestion, I will try that
Offline giusCB
  • www.turismometeo.it
Re: WS68 Surgery
« Reply #9 on: March 13, 2023, 04:10:56 AM »
any news about that ?
www.turismometeo.it
Offline Gyvate
Re: WS68 Surgery
« Reply #10 on: March 13, 2023, 04:32:30 AM »
I think you'll have to watch this thread  starting from - https://www.wxforum.net/index.php?topic=45064.msg457746#msg457746
from their announcement Ecowitt won't send the test kit out before beginning of April - see reply #50, same thread
Offline box
Re: WS68 Surgery
« Reply #11 on: March 13, 2023, 04:35:20 AM »
Thanks, a mine of information as always! :grin:
