Author Topic: GW1000 Sudden Radio Strength Issues With WS90  (Read 218 times)
Offline tweatherman
« on: February 18, 2023, 01:59:51 AM »
Has anyone here ever experienced sudden radio strength issues from WS90? I have had zero issues with this over the last year. GW2000 is having no issues connected to the same station. I did a factory reset and radio reception strength was good for a few minutes then signal strength went done slowly and in the same boat now with it not connecting to the station. Time to get another GW1000?
tweatherman
« Last Edit: February 18, 2023, 02:04:29 AM by tweatherman »
Offline davidefa
Re: GW1000 Sudden Radio Strength Issues With WS90
« Reply #1 on: February 18, 2023, 04:07:30 AM »
The gw1000 antenna orientation is also important ( especially if there is quite some distance/walls/obstacles between gateway and sensors ).
As a rule of thumb keep the antenna vertical.
My gw1000 has a "spring antenna" like this ( the arrow shows the up direction ):
Other gw1000 revisions have a wire antenna, in this case unfold and straighten the antenna out of the gw1000 box
Offline tweatherman
« Reply #2 on: February 18, 2023, 04:16:50 PM »
Thanks but position hasn't changed in a year.
tweatherman
Offline Rover1822
« Reply #3 on: February 18, 2023, 04:57:53 PM »
Then sadly, there is more than likely an issue with the unit.
I have had many issues with the WS90 , yours is not one one of them.
Doesn't make it less important, just that I haven't experienced it.
I know, I haven't helped , contact Ecowitt, these have not been around that long, and maybe , they will provide you support on the unit or a replacement.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
