I did call Ambient after the first one failed and goot a real nice lady on the phone. Today I didn't get any real help and they just said deal with Amazon. They do say three's a charm so maybe that's what I need is a 3rd one. At least I saved the box to put it in. I did give it a fresh water rinse and covered solar and will see tomorrow if it works. It's already stopped sending any data to console and red light on Y wing is dead so I assume solar batteries are dead already.
Maybe slow down a bit with assumptions and don't jump the gun.
Stating in another thread here in the forum that the outdoor conditions are responsible for your station(s) to fail has not been properly verified yet (maybe just a connector got loose during transport and the wind and resulting vibrations did the rest, who knows - that's for missing outdoor T/RH readings) and might be pre-mature. You'd better say "I assume, I suspect" rather than "it is" until the cause has really been found - if ever.
The only thing which is clear is that either your console or your array (or both) don't behave properly.
For the console to misbehave the outer conditions cannot be a reason.
If the array is really faulty you don't know as you don't have another console to compare.
When the LED on the array is off now the batteries which are meant to be backup only will have expired.
And should be replaced for any further investigation.
You didn't post a picture from the console display as requested !
This could have given some more indications - now too late - except after exchanging the batteries the array starts working again and the console starts receiving again. Then you could/should make a picture of the console display and post it.
There's too much speculation involved without systematic error search ....
Lack of pressure data indicates something wrong with the console !
But, given the general experience, I'd suggest, you get yourself a refund from Amazon (the whole lot/batch in the Amazon store might be faulty
- and we still don't know where exactly the issue is located), and get yourself a HP2553 from Ecowitt instead - either via their Amazon store or directly from Ecowitt in China - they ship reliably. In addition, get yourself a GW1100 displayless console (30 USD only). It will be very helpful for you in many ways (not only for diagnostic purposes) and many users get themselves a GW1100 in addition to a HP2553 station.
The HP2553 comes with the HP2551 console, a 6-in-1 sensor array with an ultrasonic anemometer, a separate rain gauge and it has already shown resistance to coast exposure with some forum users (even though noone can gurantee anything).
It's a very solid station with a lot of additional potential functionality and known hardware failures are comparatively rarely reported here.
Even though we rather rarely get complaints for the WH2910 and WS2320E stations here (WH2910 = Ambient WS-2902) either.
