Author Topic: WS80 Protection  (Read 835 times)
Offline Rocketman
WS80 Protection
« on: February 08, 2023, 01:13:09 AM »
Just wondering if there's
any product to help protecti the solar panel cover at the top of the weather station . I noticed a slight discolouration in the cover ( is there anything we can spray on it )
« Last Edit: February 08, 2023, 02:31:53 AM by Rocketman »
HP2550 console 1.8.7 firmware  , WS80 weather station , WH57 lightning sensor , WH40 rain gauge , WH51 soil moisture sensor , GX1100 gateway 2.2.1 firmware
Offline Gyvate
Re: WS80 Protection
« Reply #1 on: February 08, 2023, 03:33:02 AM »
I'd say that's rather a beauty thing. Mine is out for 2+ years now, the plastic has turned a bit yellowish and that's it.
So far it's fully functional.
Offline slybarman
Re: WS80 Protection
« Reply #2 on: February 09, 2023, 03:49:46 PM »
303 Maybe?
Offline Rover1822
Re: WS80 Protection
« Reply #3 on: February 09, 2023, 04:01:06 PM »
I don't think I would suggest anything , especially a coating, until vetted by the manufacturer
And for me a 303 is a military (British, Canadian)  , rifle round, I know, as I grew up with 2
« Last Edit: February 09, 2023, 04:04:42 PM by Rover1822 »
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline BoDuke
  • Ambient Weather, Ecowitt, WeeWX, Custom PHP
Re: WS80 Protection
« Reply #4 on: February 09, 2023, 05:38:47 PM »
I have never used it or even heard of it, but this sounds like it could be compatible with the plastics.  I don't have a WS80 or WS90 to try it on.
303 Automotive Protectant
https://www.goldeagle.com/product/303-automotive-protectant/
Offline BadWolf72
Re: WS80 Protection
« Reply #5 on: February 09, 2023, 07:19:06 PM »
What do you mean? is the solar glass not clear anymore? it could be just weathering i found with solar lights that have been out a while go like that and i just use rubbing alcohol and rinse off with plenty of water and they come up like new... i do not know if this will work on the ws80 or ws90 i only had mine about a month so i cannot say if it will work or if it may even damage the top of the unit.
I agree with Rover1822 i would email Ecowiit and ask there advice before using any coatings or cleaning chemicals.
Martin
« Last Edit: February 09, 2023, 07:30:31 PM by BadWolf72 »
My Weather Station Information All 868Mhz
Ecowitt wittboy                             WS90
Ecowitt weather station                 HP2551
Ecowitt Gateway                           GW1100
Ecowitt Soil Temperature               WN34S
Ecowitt Air Quality Sensor (PM2.5) WH41
Ecowitt Soil Moisture Sensor          WH51
Ecowitt Lightening Sensor              WH57
Offline Rocketman
Re: WS80 Protection
« Reply #6 on: February 09, 2023, 08:20:09 PM »
Sorry I live next to the harbour and get salt water in the air . Slight salty air tinge on the outside cover .
Offline solartempest
Re: WS80 Protection
« Reply #7 on: February 12, 2023, 12:36:36 PM »
I used jetseal on mine to make it easier to clean/resist dirt and water a bit more. Pollen and dust still sticks over time.
However, after a year so some cracking of the glass appeared underneath the top clear panel. I don't believe it's related as the top layer seems totally intact. Not sure if normal or not, unit seems to function fine still. This is what it looked like today when I did the v1.2.4 firmware update.
Ecowitt GW1000, HP2553BC, WS80, WH51x4, WH41, WH45, WH40, WH32, WH31x2, WH57x2.
Offline Rocketman
Re: WS80 Protection
« Reply #8 on: February 12, 2023, 02:53:19 PM »
might use some isopropyl alcohol on it and see what it does
Offline Rocketman
Re: WS80 Protection
« Reply #9 on: February 19, 2023, 05:42:37 PM »
Applied a coat of Starbrite Firbeglass colour restorer ( it has UV protection )
Offline Rover1822
Re: WS80 Protection
« Reply #10 on: February 19, 2023, 05:51:21 PM »
So, you just applied a product, without actually having an issue?
And a restorer product meant for fiberglass, usually applied for things like crazing, after the crazing has occurred?
Edit : That is the kind of stuff I would use to brighten up old gel coat on a boat hull. Did someone advise you that this was a good idea?
« Last Edit: February 19, 2023, 06:00:46 PM by Rover1822 »
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline Rocketman
Re: WS80 Protection
« Reply #11 on: February 19, 2023, 06:21:59 PM »
Yes , i did have slight colour fading ( gone a bit cloudy )
WS80 is only about 2 months old
says on the product - special polymers protect against damaging UV rays and repel stains
doesn't mention anything about crazing
anyways I'm close to the harhour and get effected with saltwater spray
« Last Edit: February 19, 2023, 10:21:47 PM by Rocketman »
Offline Rover1822
Re: WS80 Protection
« Reply #12 on: February 20, 2023, 12:14:17 PM »
I looked at the product , it is not something I would have used, it might work, but not really meant for the purpose. When I said crazing, hazing, would have more appropriate. It is also formulated for fiberglass, which is quite different than the plastic you applied it to.
The other thing is it has UV inhibitors, we usually frown on putting anything like that over a solar panels or sensors, it is like smearing them with sunscreen. From the product description and components, no where does it suggest using it on a clear surface.
I'm just posting this , as the forum posts are read by many many people, and really don't want them to rush out and buy the product you listed just because you said you used it. If it works, fine, but I wish you would have said something like "I'm going to try ... "
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Re: WS80 Protection
« Reply #13 on: February 20, 2023, 12:26:04 PM »
This is a good point. We do know that the WS80 solar sensor is... maybe not the best implementation, but it is something. The sensor is reactive to UV light (and I have tested this), so if you do start blocking the UV it will likely shift your readings a little.
Offline Rocketman
Re: WS80 Protection
« Reply #14 on: February 20, 2023, 03:56:36 PM »
Attached Solar & UVI over 7 days - Starbrite product was applied on the evening of 19th
« Last Edit: February 20, 2023, 08:16:44 PM by Rocketman »
Offline Rocketman
Re: WS80 Protection
« Reply #15 on: February 21, 2023, 02:50:43 PM »
2 days of Sun with Starbrite product
Offline slybarman
Re: WS80 Protection
« Reply #16 on: February 21, 2023, 02:53:11 PM »
Does that mean it dropped from a peak of 1348 to to 1274 after applying the product?
Seems like comparing both at the same day/time is the only way you would know for sure
Offline Rocketman
Re: WS80 Protection
« Reply #17 on: February 21, 2023, 03:05:26 PM »
I don't think so as the days have been partially cloudy
Offline slybarman
Re: WS80 Protection
« Reply #18 on: February 21, 2023, 03:09:13 PM »
what am I supposed to be taking away from these charts?
Offline Rocketman
Re: WS80 Protection
« Reply #19 on: February 21, 2023, 04:34:40 PM »
Just showing the output is about the same ( I'm going to apply a second coat of Starbrite as that's what the product suggest )
Offline slybarman
Re: WS80 Protection
« Reply #20 on: February 21, 2023, 05:00:47 PM »
I'm not sure how you could tell that if the sun amount is always changing, but i should add that i am no scientist, engineer or meteorologist.
