Author Topic: WH40 calibration - controlled enviroment  (Read 419 times)
Offline Rocketman
« on: February 07, 2023, 07:15:09 PM »
If I take 2 litres of water and sit above the drip tray of the WH40 and see how much is measured ?
Would I expect 2000 mm to be measured ?
HP2550 console 1.8.7 firmware  , WS80 weather station , WH57 lightning sensor , WH40 rain gauge , WH51 soil moisture sensor , GX1100 gateway 2.2.1 firmware
Offline Gyvate
Re: WH40 calibration - controlled enviroment
« Reply #1 on: February 08, 2023, 03:49:25 AM »
I don't think it is that simple.
The unit is mm/m2 - the amount of rain falling one m2 of surface. One tip of the WH40 rain gauge corresponds to 0.1022 mm
The funnel surface is not 1 m2 but much less. You can calculate the surface by simple geometrical math(s) measuring its diameter.
But I'm not going to do the math work for you now  8-)
EDIT:
I think, what you want to do is not see if two litres come out when you pour two litres in - that's trivial.
I think you want to know what your console shows as measured rainfall
« Last Edit: February 08, 2023, 08:20:39 AM by Gyvate »
Offline hiljo
    • Weerstation Marsdijk
« Reply #2 on: February 08, 2023, 06:53:22 AM »
Yes, because you drip it in a controlled environment, 2L is 2L. But the question is why would you want that?
Ecowitt HP2550C v1.8.7
GW2000 v2.2.2
Beta WittBoy WS90 v1.3.0
3x WH31, WH32, WH40, WH41, WH57
WN34L, 2x WH51, WN35
Dutch translator for Ecowitt.
https://www.weerstationmarsdijk.nl/
Offline davidefa
« Reply #3 on: February 08, 2023, 07:26:19 AM »
Sorry, no, 2 liters of water in the wh40 funnel will not record 2000mm of rain.
'Build a cilinder with 2 liters volume' with the same area base as the aperture of the wh40, the height of the cilinder is the amount of rain that should be recorded.
Using cm as unit of measure ( assuming diameter of wh40 funnel=7", base area=248.16cm2, not sure this is correct/accurate, but it was reported on the forum ):
2000cm3/248.16cm2=8.059cm=80.6mm
P.S.
My math is not so good, had to edit the post a couple of times : - (
« Last Edit: February 08, 2023, 07:55:38 AM by davidefa »
Offline Gyvate
« Reply #4 on: February 08, 2023, 08:31:26 AM »
@davidefa
that's doing the math for the OP. :roll:
I would have wanted him to this himself  8-)
see my edited post
it depends where he measures what:
if he puts a container under the WH40, he will measure 2 litres  ;)
if he looks at the console, the meausred rainfall will of course be different as the funnel doesn't have 1 m2 surface but only around a quarter of it.
(diametre)2 x pi / 4 is the formula - so your calculation based on 7 inches = 17.78 cm is correct
Offline hiljo
« Reply #5 on: February 08, 2023, 01:26:41 PM »
But if you take a measuring cup, fill it with exactly 2000mL of water (or another amount), and pour it in slowly so the cup has the time to flip, 2000mL should be measured right?
GW2000 v2.2.2
Online Rover1822
« Reply #6 on: February 08, 2023, 01:36:37 PM »
You will have measured 2000 ml. I'm being facetious here, because you are measuring 2000 ml and what it will produce as a reading.
You will not get 200O ml as and output from the sensor. As Gyvate explained, the units are totally different and depend on surface  area, which can be worked out to volume per surface area.
mm per meter squared, the area of the cone is no where near a meter squared, so you have to do some math for the actual area. Once you do that , also the volumetric portion, you will arrive at a calculation for volume to mm per meter squared, for the volume you dumped into the sensor.
Edit to maybe explain further: The sensor knows it doesn't have a 1 meter square cone, it does know the surface area it has, it can measure the volume of rain that past through the bucket. It then extrapolates the known volume, (based on mass to tip the bucket) , and then can build a number as if it collected that number as though it does have a 1 meter square cone.
« Last Edit: February 08, 2023, 01:51:46 PM by Rover1822 »
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline hiljo
« Reply #7 on: February 08, 2023, 07:00:29 PM »
Ah now I get it. One tip of the WH40 isn't 1mm, but is extrapolated so it represents 1mm of rainfall (over 1m2).
I thought that 1 tip was really 1mm, not extrapolated  #-o
GW2000 v2.2.2
Offline Gyvate
« Reply #8 on: February 08, 2023, 07:26:06 PM »
in fact one tip equals 0.102 mm/m2, not 1 mm
« Last Edit: February 08, 2023, 08:15:18 PM by Gyvate »
Offline Rocketman
« Reply #9 on: February 08, 2023, 08:12:47 PM »
So 2000 mils of water spread over 248.16 cm X 8.059cm ( measured height for that volume ) 80.59 mm
« Last Edit: February 08, 2023, 10:39:54 PM by Rocketman »
