Author Topic: WS80 cal button  (Read 338 times)
Offline Rocketman
WS80 cal button
« on: February 07, 2023, 05:02:49 PM »
Why does the WS80 have a CAL button ?
Is it used for calibrating ?
HP2550 console 1.8.7 firmware  , WS80 weather station , WH57 lightning sensor , WH40 rain gauge , WH51 soil moisture sensor , GX1100 gateway 2.2.1 firmware
Offline Gyvate
Re: WS80 cal button
« Reply #1 on: February 07, 2023, 05:17:26 PM »
yes, for calibrating zero speed if necessary.
Online Rover1822
Re: WS80 cal button
« Reply #2 on: February 07, 2023, 05:25:45 PM »
Adding, if like the WS90, which I am sure this is, you want to do the calibration is a static environment, NO AIR MOVEMENT, so a box or enclosure would be preferred. Just using the button in situ , or where it is placed , not recommended.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Online Rover1822
Re: WS80 cal button
« Reply #3 on: February 07, 2023, 05:34:37 PM »
Frankly, I have needed to calibrate the WS90, and from a bunch of previous posts, I don't see anyone needing to calibrate the WS80.
Hey, curiosity is good, just don't get the impulse to use a button because it exists.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline Rocketman
Re: WS80 cal button
« Reply #4 on: February 07, 2023, 06:00:27 PM »
 [tup] Lucky, I haven't pressed the CAL button
Now I know what it is used for
Offline hiljo
    • Weerstation Marsdijk
Re: WS80 cal button
« Reply #5 on: February 08, 2023, 10:19:56 AM »
I had to calibrate the WS90 too. Additional: after each firmware update of the unit itself, I calibrate it, to know I'm sure the zero wind baseline is set correctly. In the last firmware eg. there were optimizations made for low wind speeds. Therefore used the calibration button to make sure the low wind speeds were reset and properly detected.
Ecowitt HP2550C v1.8.7
GW2000 v2.2.2
Beta WittBoy WS90 v1.3.0
3x WH31, WH32, WH40, WH41, WH57
WN34L, 2x WH51, WN35
Dutch translator for Ecowitt.
https://www.weerstationmarsdijk.nl/
Offline slybarman
Re: WS80 cal button
« Reply #6 on: February 10, 2023, 07:44:46 AM »
It is almost cruel to put a button on something then tell people not to push it.
Offline davidefa
Re: WS80 cal button
« Reply #7 on: February 10, 2023, 09:13:17 AM »
This should be more appropriate in my case, not exactly a button ( but the result is generally the same ):
