Author Topic: HP2551 console & WN32CP unit  (Read 158 times)
Offline Rocketman
« on: February 06, 2023, 08:17:58 PM »
Currently my HP2551 console gets a pressure reading from WN32CP unit .
Can I get the reading for barometer from the GW1100 unit ?
HP2550 console 1.8.7 firmware  , WS80 weather station , WH57 lightning sensor , WH40 rain gauge , WH51 soil moisture sensor , GX1100 gateway 2.2.1 firmware
Online Gyvate
Re: HP2551 console & WN32CP unit
« Reply #1 on: February 07, 2023, 08:00:17 AM »
this depends on your scenario:
- with a GW1100 you can get its pressure readings  ;)
- on a HP25x0 display you can't get the readings from the GW1100 pressure chip
when you want to get (+/-) its readings on the HP25x0 console, you can place your WH32B close to the GW1100 location 8-)
- with a GW1100 you can get the readings of the WH32B (WH32 indoor) though - when you remove (cut/unsolder) the T/H sensor wires of the GW1100
