Author Topic: New console WN1821C - with integrated CO2 sensor!  (Read 343 times)
Offline olicat
    • FOSHKplugin
« on: February 06, 2023, 05:22:00 PM »
Hi!
Has anyone noticed the new WN1821C console or even used it yet?
The really interesting thing about it is the built-in CO2 meter. I wonder which sensor is installed there?
And whether - as with the WH45 - a fan starts up every time a measurement is taken?
According to the manual, this console also supports another WH45.
I wonder how these different sensors are actually transmitted via the Ecowitt protocol.
So if anyone is already using this device, please let it send to EAR as a test.
Thanks a lot!
add:
The new keys for the internal CO2 sensor are probably called co2in and co2in_24h according to the firmware.
add2:
Ecowitt.net already knows this sensor and displays it accordingly as "Indoor CO2":
So the key names are indeed co2in & co2in_24h.
Oliver
Offline davidefa
Re: New console WN1821C
« Reply #1 on: February 06, 2023, 05:45:16 PM »
Considering the price ( 15$ more than wn1980_c ) can't be an ndir co2 sensor.
I think probably one of those eco2 sensors ( something like this ).
Offline olicat
    • FOSHKplugin
Re: New console WN1821C - with integrated CO2 sensor!
« Reply #2 on: February 06, 2023, 05:58:59 PM »
Hi!
The good thing about it: a fan is probably not necessary. The question is, of course, how valid the "measured" values are.
But I can't buy another new console just to test it - my wife beats me ...
Fortunately, the device is not yet available. The Shopify shop doesn't have it in its range yet.
Yet!
Oliver
Offline Gyvate
« Reply #3 on: February 07, 2023, 08:37:01 AM »
so basically it's a WN19x0 with CO2, WH31, WN34, WN35 display and without rain, wind and pressure display.
And I think the display pictures in the manual are wrong - they do not match the product page (are probably taken from a WN19x0 manual).
Wondering if it can really show two (internal, external CO2 combo) sensors at the same time (on ecowitt.net) - the local API doesn't allow for two CO2 sensors though (or it got extended). Maybe the WiFi firmware portion for posting to Ecowitt.net does ...
to be verified
Offline olicat
    • FOSHKplugin
« Reply #4 on: February 07, 2023, 08:44:38 AM »
Hi!
It can (at least on Ecowitt.net). Verified.
The trick is to use new key names. Have a look to the two new keys mentioned in post #1. There's also a screenshot of the new "Indoor CO2" tile.
I expect a new GW1000-API documentation soon.
Oliver
Offline Gyvate
« Reply #5 on: February 07, 2023, 10:48:21 AM »
the owner of such a console should see the API response (e.g. with @cheeroip not yet fully functional GW1100/GW2000 app - the API response works though) and also see if new markers with respective values occur there (unless they [need to] create a new command for that).
Offline Gyvate
« Reply #6 on: February 08, 2023, 03:30:44 AM »
Ecowitt confirmed that
- the current WN1821 manual has wrong pictures and will be corrected
- the current GW1000 API does not consider the inbuilt CO2 sensor (something their design team is reflecting on now, but imho the API is unlikely to get changed for this)
- the CO2 values can be retrieved via the http API (http get)
« Last Edit: February 08, 2023, 03:42:51 AM by Gyvate »
