Author Topic: Ecowitt ECOWITT WN34BL always indicate ~2.5℉ high?  (Read 188 times)
Offline HaraldS
« on: August 31, 2022, 03:59:51 PM »
I have two Ecowitt liquid temp sensors WN34BL. Both indicate about 2.5℉ high. This is easily offset by calibration, but is this normal. Seems like a lot of offset.
Offline Rover1822
Re: Ecowitt ECOWITT WN34BL always indicate ~2.5℉ high?
« Reply #1 on: August 31, 2022, 04:06:22 PM »
OK, what are you comparing with?
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline HaraldS
« Reply #2 on: August 31, 2022, 04:07:38 PM »
Standard bulb thermometers. My electronic aquarium thermometer was calibrated against a couple of conventional ones.
Offline davidefa
« Reply #3 on: August 31, 2022, 06:00:23 PM »
I'd say ntc sensors are not known for high accuracy ( standard ntc tolerances range from 1% to 5% ).
With 1 point calibration, calibrate it at medium or normal temperature usage and you should be ok ( with the above limits )
