Author Topic: Ambient WS-2902A Issue  (Read 572 times)
Offline AK4FD
  • KNCMAIDE32
    • Gaston Spotter Skywarn Group
« on: April 08, 2020, 08:00:58 PM »
Hello all,
If there's another topic then I apologize but I did a search and couldn't find my answer...  My Ambient 2902A for the last few days has been displaying rain predictions when it's been bright & sunny and in the 80's all 3 days...  Is there a way to fix this without resetting the whole system??  Thanks.
« Last Edit: April 08, 2020, 08:02:42 PM by N1DDC »
FindU: AK4FD | Wx Underground: KNCMAIDE32 | PWSweather: AK4FD | CWOP: AV617
MesoWest: AV617 | NWS: AV617
Re: Ambient WS-2902A Issue
« Reply #1 on: April 09, 2020, 02:49:09 PM »
Your weather station is not misbehaving. There is no need to reset anything.
That little forecast icon is only there as a rough guesstimate of possible changing conditions.  The accuracy of this feature is very limited. It is basically a reminiscent hold over from when we used large analog barometers and they pointed to stormy weather if the pressure was below 29.92 inHg (1013.25 mb), and they pointed to fair sky if above this. It never was intended as something to truly depend on. Other factors are important. It is but one measure to be taken in context.
I recommend reading these knowledge base articles for further explanation:
https://help.ambientweather.net/help/forecast-icon-flashing-osprey-series/
https://help.ambientweather.net/help/my-weather-forecast-is-incorrect-it-does-not-reflect-the-weather-outside/
Offline AK4FD
  • KNCMAIDE32
« Reply #2 on: April 09, 2020, 03:44:26 PM »
 :thumbsup:  Thank you for your reply sir!
Offline Wayne Orwig
« Reply #3 on: April 10, 2020, 11:15:57 AM »
Have you calibrated or checked your barometer?
« Reply #4 on: April 10, 2020, 11:42:19 AM »
His barometer looks spot on perfect. Looks like he has fine tuned it like a trained professional, very impressive.
N1DDC QC:
https://weather.gladstonefamily.net/site/AV617
Offline AK4FD
  • KNCMAIDE32
« Reply #5 on: April 10, 2020, 12:10:53 PM »
Oh now I can’t take any credit for the fine-tuning...  :thumbsup: :D
I do have something else tho I need help with.  My Ham callsign changed this morning from N1DDC to AK4FD, how can I get that changed on all my listings?
Online Rover1822
« Reply #6 on: April 10, 2020, 12:28:40 PM »
If you change it in your profile, forum profile settings. It will automatically change the display on current and previous posts
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline AK4FD
  • KNCMAIDE32
« Reply #7 on: April 10, 2020, 12:40:10 PM »
No I meant on all my weather device listings, my Wx station is registered to my ham callsign.
« Reply #8 on: April 10, 2020, 02:01:02 PM »
Why did your ham callsign change?
If you want to use a different callsign you have to register them all with each service as if you were starting new. There is no renaming possible.
Even on this forum, you can't change your username. You can change your displayed name but the username is still the same. Also I see your registered email includes your old ham callsign. You'd have to register for a new email address too, right?...to be consistent I would assume.
That all seems like a lot of work. Seems that you recently registered for all these services. Did you not know you were changing call signs? I've never heard of someone changing callsign. I've seen people move and they keep using their existing callsign. So I'm just curious how this came about.
Offline AK4FD
  • KNCMAIDE32
« Reply #9 on: April 10, 2020, 03:30:44 PM »
I had sent in to change my callsign almost 2 months ago and hadn’t heard anything so I had just figured it had gotten denied or something or the FCC wasn’t operating at this time so I just went ahead and set up my weather station as it was, I didn’t wanna wait and not start feeding my Wx station data because I wasn’t sure if or when I would be hearing back about it, we all know how the government is right now.  Then POOF I woke up this morning and it was done.  So to make it easier I don’t wanna derail this topic & I will just leave everything as-is so nobody has to be bothered with it and the stream doesn’t get interrupted.
« Last Edit: April 10, 2020, 03:32:50 PM by N1DDC »
Online Rover1822
« Reply #10 on: April 10, 2020, 03:53:51 PM »
Naw, I get it.
but  with these... you can simply change them as they are just labels to your new one
"FindU: N1DDC | Wx Underground: KNCMAIDE18 | PWSweather: N1DDC | CWOP: AV617
MesoWest: AV617 | NWS: AV617"
As far as your nick ... you can change the displayed name .. no problem there
I know , doesn't get you through all the other services etc... but partial anyway.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
