Hi all,
Long time lurker but first time poster so please be gentle with me
I got myself a WS-1001 (HP-1001 over here in Australia
http://ss-tradings.com.au/Solar-Powered-Wireless-Weather-Station-with-WiFi-Connection-P3086172.aspx last Christmas and for the first couple of months it was good. Had no problems registering with Wunderground (
http://www.wunderground.com/personal-weather-station/dashboard?ID=ISOUTHAU196) and have been able to observe it quite happily since I have had it.
I originally registered with WXforum back when I had an anomaly occur on the 4th of March where at 11:38pm I had a very sudden spike in the outdoor temperature where it went from 18.2°C to 31.9°C in the space of 30 minutes:
http://www.wunderground.com/personal-weather-station/dashboard?ID=ISOUTHAU196#history/s20150305/e20150305/mdailyThe day leading up to that night the maximum temperature had been 24.5° at about 3:30pm and had been steadily dropping since then
http://www.wunderground.com/personal-weather-station/dashboard?ID=ISOUTHAU196#history/s20150303/e20150303/mdaily. After the temp spike it then dropped fairly sharply before a steady rise for about an hour before a steady dropoff for for another hour and a half until settling down again at what I would consider the accurate temperature for that night of about 18°.
The nearest weatherstation to me (with identical hardware - about 2km away from me) had nothing like that - they maintained a steady temperature all night that night. Their station is down at the moment so I can't link to them unfortunately.
So I thought that I would see what happened over the next few days and nights but nothing really happened so I just put it down to a glitch in either the transmitter or receiver.
So, moving along to the start of this month and we had our first significant rainfall for the year (we went 61 days with no more than 1mm of precipitation on any of those days!!) and of course the rain gauge in the station decided to stop working (it stopped at 3.7mm when we had closer to 11mm according to our offical Bureau of Meteorology Weatherstation located about 5km away
http://www.bom.gov.au/climate/dwo/IDCJDW5046.latest.shtml).. So I climbed up on the roof and took it down. Gently pulled it apart and sprayed a bit of lubrication on the hinges for the bucket and put it back together. Since then we have had trace amounts of rainfall and they have registered fine - in fact it is raining lightly here as I type now
After putting it back up I noticed that the humidity and dew point readings seemed very low so I manually calibrated the base unit using a combination of readings from the nearby Government weather station as well as the other WU connected weather station that I mentioned before. this seemed to resolve that issue as well.
So today my unit seems to have had a major issue occur:
At 11:41 this morning the outside temperature and outside humidity measured by the unit shot up (11° in 1/2 an hour). It then went down 9° in 20 minutes. Then the humidity plummeted to 1% and has stayed there since. The part that measures the humidity is obviously not working as the other stations in the area have humidity at the moment as between 90%-99% due to the rain we are having. It has been overcast here all day so I don't think that sunlight was the issue.
Just wondering if anyone has seen anything like this and do you think that I should be arranging with the retailer that I purchased it from for an exchange?
