Author Topic: NOTICE: RAW DATA ERROR DETECTED.  (Read 3235 times)
Offline NikosB
    • Peristeri center
« on: August 26, 2009, 02:34:50 PM »
Hello everybody.
Did someone else receive this message?
I am on Vista 32 bit . The station is TFA Matrix and WD 10.370 built 2.
Regards
NikosB
http://www.weather.comxa.com/index.php
                   TFA Matrix II
Offline Weather Display
Re: NOTICE: RAW DATA ERROR DETECTED.
« Reply #1 on: August 26, 2009, 02:44:57 PM »
do you mean an email from CWOP?
Brian
info@weather-display.com
Offline NikosB
    • Peristeri center
« Reply #2 on: August 26, 2009, 04:17:27 PM »
No. I Will try make it more clear.
The problem is that don't upload the clientraw file.
So i went to TNET website where i used the "WD ClientRaw Parser" and i received this message.
Now that i tried, also to upload wxlocal i see that NOTHING upload. The icon in the system tray presented that has make the "job" but in my site i see nothing.
If someone can help i appreciated.
Rgrds
NikosB
                   TFA Matrix II
« Reply #3 on: August 26, 2009, 04:41:05 PM »
which version of WD?
what shows in the Ftplogfull.txt file?
Brian
Offline NikosB
    • Peristeri center
« Reply #4 on: August 26, 2009, 05:01:46 PM »
Hi
1)WD 10.370 build 02.
2)ftplogfull = NO ERRORS
Rgrds
                   TFA Matrix II
« Reply #5 on: August 26, 2009, 05:03:47 PM »
make sure you have set to log the ftp details in the connections setup
also make sure the main internet switch is on there, and make sure you have ticked to use weather display's Ftpupd.exe
Brian
Offline NikosB
    • Peristeri center
« Reply #6 on: August 26, 2009, 05:16:03 PM »
ALL you mentioned are as you wait. CORRECT. !
                   TFA Matrix II
« Reply #7 on: August 26, 2009, 05:29:47 PM »
if you are only using the clientrawrealtimeftp.exe
then double click on that icon in the system tray and see what the ftp messages are
(and make sure you have the correct ftp settings in the real time ftp setup)
also check your firewall is not blocking
also often passive mode needs to be set
Brian
Offline NikosB
    • Peristeri center
« Reply #8 on: August 26, 2009, 06:06:55 PM »
Hi
I hope in attachment can read the FTP message.
NikosB
                   TFA Matrix II
« Reply #9 on: August 26, 2009, 06:43:28 PM »
would be better to have copied/pasted the message
but I can make out that the problem is you need to untick use file rename
in the real time ftp setup and in the main connections setup
then exit and restart the clientrawrealtimeftp.exe
as your web site /ftp server does not allow file rename
Brian
Offline NikosB
    • Peristeri center
« Reply #10 on: August 26, 2009, 07:15:42 PM »
OK GBW.
I have unticked the file rename and seems works OK.
In the other hand, when i check with TNET tool, i receive the same message.
"NOTICE: RAW DATA ERROR DETECTED. Your datafile does not appear to be in the correct format.
Raw Data
Peristeri-center multilingual Website.
103.8
Peristeri Athens, Greece
Language: en
Updated:  27/08/2009 02:10  "
Any more help ???
Rgrds
NikosB
                   TFA Matrix II
Offline ALITTLEweird1
  • Mark
    • North Bend Weather
« Reply #11 on: August 26, 2009, 07:59:39 PM »
What directory do you have your clientraw files uploading too? You should try and put all of your website files and clientraw files in the same directory. Its makes it so much easier.
not found here..
http://www.weather.comxa.com/clientraw.txt
UPDATE: found it here.. http://www.weather.comxa.com/clientraw.txttmp
Go to the Control panel..webfiles/webpage..realtimeclient ftp tab...then uncheck "rename the file as a temp file"
and you need to rename your wxindex.php to index.php
« Last Edit: August 26, 2009, 08:06:15 PM by ALITTLEweird1 »
Software: WeatherDisplay
« Reply #12 on: August 26, 2009, 08:33:14 PM »
the error on the tnet parser occurs because the clientraw.txt file is not found
(because it was not being renamed from the .txttmp file)
Brian
Offline NikosB
    • Peristeri center
« Reply #13 on: August 27, 2009, 07:02:19 AM »
Good morning ALL
"Go to the Control panel..webfiles/webpage..real timeclient ftp tab...then uncheck "rename the file as a temp file"
I have done that. Nothing changed.
I don't do that at the moment because i can see Dir and files from www.weather.comxa.com
GBW
Q : How i can change this status ???
Rgrds
NikosB
PS.
So boys i MUST thank you for your assistance!!!!!!!!!!!!!!
The problem was from ISP. Didn't allow .txt files to see in the browser.
Everything seems OK now.
One more time THANK YOU ALL.
Greetings from Athens.
NikosB
« Last Edit: August 27, 2009, 09:46:44 AM by NikosB »
                   TFA Matrix II
« Reply #14 on: August 27, 2009, 08:58:34 PM »
more often than not its a ISP/FTP server issue  #-o
Brian
