Author Topic: Indoor temperature  (Read 3040 times)
Offline Axelvold
Indoor temperature
« on: August 08, 2009, 04:31:28 AM »
Where could i find the indoor temperature in the clientraw files?
I have found the 24 hour data, but i cant find the data for 1h, 7 days, 31 days, and the yearly data.
Lars Magnusson
Axelvold / Sweden
55 57' 41" N / 13 6' 1" E
Offline floodcaster
    • Goose Lake Weather
Re: Indoor temperature
« Reply #1 on: August 08, 2009, 08:16:40 AM »
It's field #012 in the clientraw.txt.
There's a great parser utility from tnetweather at:
http://www.tnetweather.com/wd-parser.php
edit:oops not sure if that 012 field is what you are looking for but use the parser to check out the files
« Last Edit: August 08, 2009, 08:18:21 AM by floodcaster »
Bill
Offline Axelvold
« Reply #2 on: August 08, 2009, 04:22:36 PM »
What I'm looking for is indoor temperature for 1h, the last 7 days, last 31 days and if possible yearly as well.
I need those because i will make a chart with indoor and outdoor temperature so that i could see how the outdoor temp affect the indoor temp.
Lars Magnusson
Axelvold / Sweden
Offline Weather Display
« Reply #3 on: August 08, 2009, 04:41:23 PM »
that data is not available, to reduce the size of the clientraw files
i.e the line in the sand had to be drawn somewhere
however you can create custom logfiles and set to ftp them
Brian
info@weather-display.com
Offline Axelvold
« Reply #4 on: August 08, 2009, 05:11:43 PM »
Ok, i can understand that.
Where or how do i create a custom logfile?
Lars Magnusson
Axelvold / Sweden
« Reply #5 on: August 08, 2009, 05:16:37 PM »
setup, logfile setup
Brian
Offline Axelvold
« Reply #6 on: August 08, 2009, 05:28:08 PM »
where do i find the tags for the indoor temp?
I did find the tag list in the WD folder.  :oops:
« Last Edit: August 08, 2009, 05:35:02 PM by Axelvold »
Lars Magnusson
Axelvold / Sweden
Offline Arthurhh
  • IT Fixer
    • Tokoroa Weather Live
« Reply #7 on: August 08, 2009, 06:21:34 PM »
Okay a quick little excersise and I have this. :) Thanks for the idea  ;)
http://tokoroa.dyndns.org/invout.php
Other possibilities exist using the clientraw extra file
http://tokoroa.dyndns.org/wxcomparision.php
I have sent you a PM with some details in it.
Offline Axelvold
« Reply #8 on: August 09, 2009, 09:05:57 AM »
Is there custom tags to indoor temp?
I did only find those for 24h.
Lars Magnusson
Axelvold / Sweden
Offline Arthurhh
  • IT Fixer
« Reply #9 on: August 09, 2009, 04:30:06 PM »
No tag as such but the data is in the clientrawextra.txt file, it is able to be added to customout.txt under custom log creation. That will give you a csv file of the values at 1 minute intervals or greater
I am sure a tag could be added to the taglist for this if required. Pose the question to Windy
