Author Topic: Config new sensors in WD  (Read 1566 times)
Offline rebirthan1x
« on: July 25, 2009, 08:56:14 PM »
Hi there,
I have four extra sensors (+the default one = 5 overall). How must I config WD that it shows, log and get data from the datalogger with the extra sensors ? I use the wmr200a.
Thx for your help
Sven
« Last Edit: July 25, 2009, 10:24:11 PM by rebirthan1x »
Offline Weather Display
Re: Config new sensors in WD
« Reply #1 on: July 26, 2009, 02:44:33 PM »
when you go to view, wmr968/wmr200 extra sensors, you should be able to view the data there OK
and name the sensors
then also under view, extra sensor real time graph, you can setup to plot the sensors there and view them there...and use the custom to plot ability
and you can set to plot them under view, auto scale graphs...and use the customise graphs there
also there should be a extra sensor logfile as well
which version , and build, of WD?
Brian
info@weather-display.com
Offline rebirthan1x
« Reply #2 on: July 26, 2009, 03:13:59 PM »
hi, GBW
I use WD 10.370 build 02.
