Author Topic: GW3000 V1.0.9 firmware release  (Read 1103 times)
Offline Gyvate
« on: June 18, 2025, 04:32:36 AM »
New Version:V1.0.9
- Support IoT device WFC02.
- Support custom NTP servers.
- Fix the issue of repeated restarts when there is no Internet connection.
WS2350 1.7.2,GW1000 1.7.7,WH2650 WiFi 1.7.7,GW1100 2.3.7,GW1200 1.3.8,GW2000 3.2.5,GW3000 1.0.9,HP2550 2.0.5,5.2.2; HP3500 1.7.2,WS3800/3910 1.3.8,WN1910 1.2.4,WN1820/WN1980 1.3.8,WS6210 1.1.0;
Ecowitt WS90, WS85, WS80, WS68, WS69, WN30, WH31,WH31-EP, WH32,WH32-EP, WH32B/WN32P, WN34D,L,S,  WN35,WH40, WH41[PM2.5], WH45, WH46D, WH51, WH55, WH57, LDS01
Blake-Larsen Sun Recorder - RPi4/weewx 4.10.2/CumulusMX 4063/MeteobridgePro 6.1,Meteobridge RPi4B-2GB,MB VM
Barani Meteoshield Pro,MetSpecRad02,SMarTCELLino;Dracal BAR20
WIKI https://meshka.eu/Ecowitt/dokuwiki
Offline mcrossley
    • Wilmslow Astro
Re: GW3000 V1.0.9 firmware release
« Reply #1 on: June 18, 2025, 04:34:39 AM »
I'm on v1.0.8.1 and it is not finding a new version?
Web UI and WSView+
Offline Gyvate
« Reply #2 on: June 18, 2025, 04:36:38 AM »
mine came in on the WebUI - not on WSV+ - and only after active questioning. No red dot yet. It may take some time to get through
Offline broadstairs
« Reply #3 on: June 18, 2025, 05:24:09 AM »
Mine has just updated OK, just slightly strange that on initially reloading the Web UI on live data only internal values showed up but after a short while everything appeared and is now running fine.
Stuart
Offline Paulcheffus
« Reply #4 on: June 18, 2025, 06:02:50 AM »
Hi
My GW3000 has updated itself this morning 10:30 BST (09:30 UTC) but I don't have automatic updates enabled and I didn't perform the update.
Was previously at 1.0.8.1
Cheers
Ecowitt - WS2910, HP2550 & GW3000
Ecowitt Sensors - WS69, WH31, WH32P, WH57 & WH46D
Offline mcrossley
    • Wilmslow Astro
« Reply #5 on: June 18, 2025, 07:40:47 AM »
Mine has now updated via the web UI, but I notice the outdoor T/H no longer shows the transmitter id and "signal" just an antenna icon.
Offline Gyvate
« Reply #6 on: June 18, 2025, 08:28:33 AM »
I think you mean WSV+ Live data - or the sensors ID page in the WebUI
my WH32 shows there with bars ...
Maybe you have to re-register it again with its sensorID - I assume you have a backup (screencopy, paper/digital notes) for that  ;).
Offline weatherbee
    • Sherman Ct. Weather
« Reply #7 on: June 18, 2025, 11:33:15 AM »
Mine updated this morning on its own.  I don't have automatic updates enabled. First time it has done that.
Everything is working ok.
Tom
Offline olicat
  • GWxx00, HPx5x1C, WN19xxC & WS3xx0C
    • FOSHKplugin
« Reply #8 on: June 18, 2025, 12:06:26 PM »
Hi!
To all users for whom the update was automatically installed even though automatic updates are deactivated:
From which firmware version did the update to v1.0.9 take place?
I still have v1.0.6 here, auto update disabled and an automatic update has not taken place (so far?).
Oliver
Offline Paulcheffus
« Reply #9 on: June 18, 2025, 12:17:47 PM »
Hi!
I still have v1.0.6 here and an automatic update has not taken place (so far?).
Oliver
Hi
Mentioned above mine was 1.0.8.1
Cheers
Offline OldAlaskaGuy
  • Alaska, The Last American Frontier
  • An old Alaska guy living in an insane world.
« Reply #10 on: June 18, 2025, 12:23:07 PM »
Installed via auto update. All T&H sensors have signal strength indicators and ID. Although I am getting a notice of a data spike showing 0 hPa for low limit that is ongoing. Using a GW3000 to feed Cumulus and all pressure data looks good on Ecowitt. What error log should I post?
« Last Edit: June 18, 2025, 01:03:03 PM by OldAlaskaGuy »
Ambient Weather: WS-2902, IP Observer v4.6.2
Ecowitt: GW1000B: v1.7.8, GW1200B v1.3.8, GW3000B v1.0.9
Sending weather data to, Ambient CWOP, Ambient Weather, AWEKAS, Ecowitt, PWS Weather, Weathercloud, Wunderground, MADIS, and APRS
CumulusMX dashboard. V4.5.2b4505
Ambient Weather  https://ambientweather.net/dashboard/b71db9ae6b3ebd3a3db1864a6b9eeb2b
Ecowitt https://www.ecowitt.net/home/share?authorize=SEJRPK
AEKAS https://stationsweb.awekas.at/home?id=20470
Offline Gyvate
« Reply #11 on: June 18, 2025, 12:45:20 PM »
Stuart
that's normal as these are the first sensors it reads, no delay - whereas the others have to be newly "found" i.e. their next signal registered
« Reply #12 on: June 18, 2025, 01:14:48 PM »
I have rebooted my GW3000 and the error notice of a data spike on CumulusMX that is ongoing showing 0 hPa for low limit. Ecowitt is reporting normal pressures 1013-1017 hPa. What log files do you need to see the issue?SOLVED  I had inadvertently ticked to let Cumulus calculate sea level pressure. Un-ticked and saved.
« Last Edit: June 18, 2025, 03:22:25 PM by OldAlaskaGuy »
Offline broadstairs
« Reply #13 on: June 18, 2025, 01:18:08 PM »
Stuart
Yes but I have a WS80 which send data fast and I've never before seen that it was definitely slow to display!
Stuart
Offline KC5JIM
    • KC5JIM Weather
« Reply #14 on: June 18, 2025, 02:18:35 PM »
Mine auto-updated(auto updates enabled), and there have been no issues.
Ecowitt Wittboy|GW3000|FOSHKplugin on Pi 4
Offline weatherbee
« Reply #15 on: June 18, 2025, 02:35:17 PM »
Mine auto updated from version 1.0.8.1.
Tom
Offline mcrossley
    • Wilmslow Astro
« Reply #16 on: June 18, 2025, 02:37:22 PM »
It's fixed itself, I just reopened the WSV+ app and the outdoor T/H now shows the sensor id and signal
Offline Rocketman
« Reply #17 on: June 19, 2025, 04:58:49 AM »
My Gw3000 was on 1.0.6 updated manually to 1.0.9 ( all OK )
HP2550,FW 2.0.4, WS80 FW1.2.9, WH57 , WH40 , WH51, GW1100 FW2.3.4 , WN90LP FW1.4.7 wirelessly to Hongyuv HY Display, INKBIRD iAMQ-128W V1.1, WH55 x 2 , WN34D,Vector Instruments A101M & A101K , CumulusMX 4.4.5 b4088, Weather Display 10.37S 152
Offline Gyvate
« Reply #18 on: June 19, 2025, 05:03:48 AM »
Ecowitt pushed a forced 1.0.9 upgrade to all 1.0.8.1 GW3000 gateways as the change with the reboots in 1.0.9 should have been already included.
Or, the other way around, 1.0.8.1 was in a way premature (a hot fix) but was released earlier to avoid custom server issues with WH45/46/46D owners
That was exceptional and only 1.0.8.1 gateways were affected.
Offline Dirk27
« Reply #19 on: June 19, 2025, 06:34:19 AM »
Until now I've watched this "overriding" of the disabled automatical firmware update setting only two times:
This GW3000 update and the HP10 update to V1.1.0.
Dirk
Ecowitt GW1100, GW1200, 2x GW2000, GW3000, WH57, 4x WN31, WN34D, WH0291_C, WH51, WH0290_C, WH41, HP10, LDS01, AC1100, WFC01, WN1980_C, WN1821_C
Froggit HP1000SE PRO, T&HP [WN32P], DP1100, DP80, 2x WH2626, 2x DP40, DP30, DP250, DP10, DP70
DNT DNT000005 [WH32F]
[Out of order: Galileo's Thermometer, Crystal Ball, Fitzroy's Storm Glass]
Beginners' WiKi: https://meshka.eu/Ecowitt/dokuwiki/doku.php?id=beginners
Offline zoomx
« Reply #20 on: June 19, 2025, 11:11:35 AM »
Me too found 1.0.9 and I didn't have the automatic update so it was forced. I had  1.0.8.1
Offline CloudyDave
« Reply #21 on: July 11, 2025, 06:19:38 PM »
Personally I'm very disturbed by this ability that allows for the pushing of an update when the device is configured for "NO AUTO UPDATE".  I consider this to be a critical security issue.  Has it not occured to anyone that if a rogue update was allowed to update your device with code that  monitors all of your network traffic, and send it to tim-buck-too, is not a good thing to allow under any circumstances.  I've been contemplating replacing my GW2000 with the newer GW3000 but with this discovery and the fact that this newer GW3000 version hangs when "NO INTERNET" connection (which appears to have been resolved) is available, is uncalled for.  Please educate me if you have a valid reason why this should be allowed so I can be enlightened.  This issue with the device hanging is probably the same design flaw or bug that requires me to perform a power off/on for the GW2000 on a daily basis in order to prevent the hangs that occurs with it!  Hopefully they will determine if it is the same issue and make an update available for the GW2000.  Note that I do not allow my GW2000 to have INTERNET access - only LAN.  The only time I allow internet access is when I wish to perform an update - at my discretion.  I can then monitor for problems / issues after I have allowed an update to  be performed.  Your thoughts.
Offline Vasco
    • PWS
« Reply #22 on: July 11, 2025, 06:41:01 PM »
I doubt it's a design flaw or bug - my GW2000 has been running for over a year without a hitch.
EDIT: It seems I was wrong. My apologies.
« Last Edit: July 12, 2025, 12:52:53 PM by Vasco »
Offline CloudyDave
« Reply #23 on: July 12, 2025, 12:42:37 AM »
If this an appropriate reply since I don't want to hijack this thread - I opened a new topic on my issue with the GW2000 since it's not directly related to the GW3000.
https://www.wxforum.net/index.php?topic=48715.0
Offline Gyvate
« Reply #24 on: July 12, 2025, 01:44:00 AM »
see reply in your thread - the issue is being worked on by Ecowitt - and it obviously affects not only a GW3000 or GW2000 ...
