Author Topic: new firmware for EasyWeather devices v1.7.2  (Read 509 times)
Offline olicat
  • GWxx00, HPx5x1C, WN19xxC & WS3xx0C
    • FOSHKplugin
« on: June 17, 2025, 08:30:42 AM »
Hi!
Shortly after release of v1.7.1 is there a new version v1.7.2 available for all EasyWeather devices:
Changelog EasyWeatherV1.7.2:
  • Fix the issue of time synchronization failure
Apparently this bug was introduced with v1.7.1 and has been fixed.
Use the app WS View or WSView Plus to update!
Regards, Oliver
Offline sza54
Re: new firmware for EasyWeather devices v1.7.2
« Reply #1 on: June 20, 2025, 08:04:52 PM »
I've never had any luck with updating this firmware. I have the older 2551 console (no WiFi) but all attempts to connect to it using the WS View app on my iPhone has been unproductive. I follow the prompts in the app but the buttons you need to press for the selected console don't exist on my console. I haven't noticed any anomalies with the 1.7.0 version on my console so am not too concerned.
Offline Gyvate
« Reply #2 on: June 21, 2025, 02:18:09 AM »
an older HP2550 console and no WLAN/WiFi doesn't exist (unless broken).
Everything else are other, older console models with different names.
The Upgrade is automatically offered in the WS View Plus app when the console is registred in the device list. For this it has to be connected via WLAN to your router, then WSV+ will find it.
What you describe is the pairing process - which should also work, but you can simply do this from inside the console. (gear wheel --> WiFi Scan)
WS2350 1.7.0,GW1000 1.7.7,WH2650 WiFi 1.7.7,GW1100 2.3.7,GW1200 1.3.4,GW2000 3.2.1,GW3000 1.0.3,HP2550 2.0.1,5.1.9; HP3500 1.7.2,WS3800 1.3.4, WS3910 1.3.4, WN1910 1.2.4,WN1820/WN1980 1.3.5;
Ecowitt WS90, WS85, WS80, WS68, WS69, WN30, WH31,WH31-EP, WH32,WH32-EP, WH32B/WN32P, WN34D,L,S,  WN35,WH40, WH41[PM2.5], WH45, WH46D, WH51, WH55, WH57, LDS01
Blake-Larsen Sun Recorder - RPi4/weewx 4.10.2/CumulusMX 4063/MeteobridgePro 6.1,Meteobridge RPi4B-2GB,MB VM
Barani Meteoshield Pro,MetSpecRad02,SMarTCELLino;Dracal BAR20
WIKI https://meshka.eu/Ecowitt/dokuwiki
Offline sza54
« Reply #3 on: June 21, 2025, 02:41:59 AM »
I’d not bothered to sit down and work it through but sorted it out today. All good. WS View+ saw the console once I made config change on my router. The firmware change log didn’t show a lot that was needed in my setup.
Offline Gyvate
« Reply #4 on: June 21, 2025, 08:48:19 AM »
if you were on 1.7.1, there is no not change compared to 1.7.2
if you were on an odler version, there are more changes - you have to include the earlier changelogs too
Offline sza54
« Reply #5 on: June 21, 2025, 07:43:18 PM »
What I meant to say was that my older console does not have the newer WiFi capable modem which I believe allows firmware update from the console itself.
Offline Rocketman
« Reply #6 on: June 22, 2025, 05:47:19 PM »
Have you done a firmware update for the HP2550 ? latest firmware version is 2.0.5
You can update via an SD card etc...
HP2550,FW 2.0.4, WS80 FW1.2.9, WH57 , WH40 , WH51, GW1100 FW2.3.4 , WN90LP FW1.4.7 wirelessly to Hongyuv HY Display, INKBIRD iAMQ-128W V1.1, WH55 x 2 , WN34D,Vector Instruments A101M & A101K , CumulusMX 4.4.5 b4088, Weather Display 10.37S 152
Offline sza54
« Reply #7 on: June 22, 2025, 11:20:09 PM »
Yes
