Author Topic: UV values ​​fluctuate  (Read 414 times)
Offline mandersp
    • Weerstation Afferden
« on: June 16, 2025, 11:23:15 AM »
The Froggit DP300 has a uv and solar.
Now the UV value fluctuates all the time.
How can I make the UV values ​​more stable?
I have already calibrated the UV gain to 0.7.
https://weerstationafferden.nl/pws-froggit/index.php
https://www.wunderground.com/dashboard/pws/IAFFER10
Kind regards
Piet Manders
Weather station Afferden
Online Rover1822
Re: UV values ​​fluctuate
« Reply #1 on: June 16, 2025, 11:29:01 AM »
Your post is going to open up a lot of questions, things like:
1. where is your station in relation to the sun
2. What are your shading conditions
3. What was your cloud cover , and do you get that even a blue sky may not be cloud free
So answer those first
Equipment: (I no longer list all, lets just say a bunch)
Ambient: (Various)
EcoWitt: (Various)
Personal Sites: Weather Cam
Offline broadstairs
« Reply #2 on: June 16, 2025, 12:16:59 PM »
In addition to those questions do you realise your UV sensor is not a real one but it is calculated from the solar readings.
Stuart
Offline Gyvate
« Reply #3 on: June 16, 2025, 02:33:23 PM »
without any corrections/adjustments (gain factor = 1.0) the UVI is calculated by the firmware as 10% of the solar readings and rounded to an integer number.
The WS68 (Froggit DP300) transmits readings every 16 seconds. When the solar radiation (the light intensity) measured fluctuates, usually due to clouds, automatically the UVI also fluctuates.
Factually in this time window also the UVI changes in reality as there is less solar exposure.
The smoothing of the UVI value graphs, which for whatever reason you want to have, does not reflect reality - maybe a beauty concept ... :roll:
Think about it ...
WS2350 1.7.0,GW1000 1.7.7,WH2650 WiFi 1.7.7,GW1100 2.3.7,GW1200 1.3.4,GW2000 3.2.1,GW3000 1.0.3,HP2550 2.0.1,5.1.9; HP3500 1.7.2,WS3800 1.3.4, WS3910 1.3.4, WN1910 1.2.4,WN1820/WN1980 1.3.5;
Ecowitt WS90, WS85, WS80, WS68, WS69, WN30, WH31,WH31-EP, WH32,WH32-EP, WH32B/WN32P, WN34D,L,S,  WN35,WH40, WH41[PM2.5], WH45, WH46D, WH51, WH55, WH57, LDS01
Blake-Larsen Sun Recorder - RPi4/weewx 4.10.2/CumulusMX 4063/MeteobridgePro 6.1,Meteobridge RPi4B-2GB,MB VM
Barani Meteoshield Pro,MetSpecRad02,SMarTCELLino;Dracal BAR20
WIKI https://meshka.eu/Ecowitt/dokuwiki
Offline sailingby
« Reply #4 on: June 16, 2025, 02:36:05 PM »
I’ve adjusted the gain on mine to get realistic levels for the uk.
Unadjusted I would be getting a great suntan in April  :lol:
HP2560, WS68, WN32, WH40, WH57, WH41, WH46D & WN31x4
https://www.wunderground.com/dashboard/pws/ISTAMF8
Offline Gyvate
« Reply #5 on: June 16, 2025, 02:39:37 PM »
that's fine - we recommend using a gain factor between 0.65 and 0.75. The individual local best fit is to be determined at a (visible) cloud free day in summer by comparing your readings with an as close-by as possible official metereological station with real UV sensors and fine tune your gain factor that way.
However, that will not smoothen the UVI graph  ;)
Offline sailingby
« Reply #6 on: June 16, 2025, 02:42:11 PM »
That’s the gain factor range I've used, tweaked a to match up on a clear day to Apple weather.
Offline Vasco
    • PWS
« Reply #7 on: June 16, 2025, 02:43:13 PM »
To make mine read anything like real values I use 0.6, and that doesn't work all the time.
In addition to all the above, please note that the solar/UV sensor is very susceptible to solar amplification from "fair weather" clouds, so readings are often higher than the theoretical maximum for lat/long/date. . .
Offline sailingby
« Reply #8 on: June 16, 2025, 02:44:18 PM »
Ecowitt were asking for feedback a while back, re development of an independent uv sensor. Is there any news on this?
Offline Gyvate
« Reply #9 on: June 16, 2025, 02:55:03 PM »
that latitude dependent solar max value is rather theoretical (see also our WiKi) - events like e.g. the often occurring cloud-edge-effect are not considered.
The high readings are real and seriously considered in the photovoltaic area - but they may not look as beautiful as the theoretical solar max bell curve  \:D/
Offline Gyvate
« Reply #10 on: June 16, 2025, 02:58:19 PM »
as far as I know this is still under consideration - it's also a business case - how many will buy such a special device which will not be cheap, will others be willing to pay a higher price if this were integrated into new editions of existing sensor arrays, etc. compared to the R&D costs ...
Offline Vasco
    • PWS
« Reply #11 on: June 16, 2025, 03:08:16 PM »
Agreed.
But it's interesting (to me) that WU (WD upload, not gateway) doesn't seem to show the highest values recorded by Ecowitt. . . which is probably because I only upload every 5 minutes for both of them.
Offline mandersp
« Reply #12 on: June 17, 2025, 11:14:55 AM »
Thanks for all the information.
I know enough, thanks for that.
Kind regards
Piet Manders
