Author Topic: firmware 2.0.4 ?  (Read 228 times)
Offline Billyram
    • The Rapids
firmware 2.0.4 ?
« on: June 14, 2025, 11:08:14 AM »
What does this do for HP2560 console?
HP2560 Console
WS5000 Sensor Array
WH40H Rainfall Sensor
WH57 Lightning Detection
CumulusMX
https://www.ecowitt.net/home/index?id=253478
https://www.wunderground.com/dashboard/pws/KSCNORTH351
Offline olicat
  • GWxx00, HPx5x1C, WN19xxC & WS3xx0C
    • FOSHKplugin
Re: firmware 2.0.4 ?
« Reply #1 on: June 14, 2025, 11:13:36 AM »
Hi!
Have a look to the Changelog:
HP2550 & HP2560 V2.0.4_ 2025-03-25
  • The Gust value stored in the SD card is the maximum value of the last 2 minutes
  • Supports the LDS01 data filter level algorithm
  • Fix some abnormal display bugs
Or what did you mean by your question?
Oliver
Offline Gyvate
« Reply #2 on: June 14, 2025, 11:58:19 AM »
it adds functionality or corrects errors from former firmware versions.
Between your actual firmware and 2.0.4 there may be several versions:
for a more complete description, see our WiKi
https://meshka.eu/Ecowitt/dokuwiki/doku.php?id=start#console_firmware_changelogs
WS2350 1.7.0,GW1000 1.7.7,WH2650 WiFi 1.7.7,GW1100 2.3.7,GW1200 1.3.4,GW2000 3.2.1,GW3000 1.0.3,HP2550 2.0.1,5.1.9; HP3500 1.7.2,WS3800 1.3.4, WS3910 1.3.4, WN1910 1.2.4,WN1820/WN1980 1.3.5;
Ecowitt WS90, WS85, WS80, WS68, WS69, WN30, WH31,WH31-EP, WH32,WH32-EP, WH32B/WN32P, WN34D,L,S,  WN35,WH40, WH41[PM2.5], WH45, WH46D, WH51, WH55, WH57, LDS01
Blake-Larsen Sun Recorder - RPi4/weewx 4.10.2/CumulusMX 4063/MeteobridgePro 6.1,Meteobridge RPi4B-2GB,MB VM
Barani Meteoshield Pro,MetSpecRad02,SMarTCELLino;Dracal BAR20
WIKI https://meshka.eu/Ecowitt/dokuwiki
Offline Billyram
    • The Rapids
« Reply #3 on: June 14, 2025, 01:44:30 PM »
Hi!
Oliver
Thank you
HP2560 Console
WS5000 Sensor Array
CumulusMX
Offline Billyram
    • The Rapids
« Reply #4 on: June 14, 2025, 01:45:01 PM »
Thank you
HP2560 Console
WS5000 Sensor Array
CumulusMX
