Author Topic: WS68 after 3 yers  (Read 256 times)
Offline Dador
    • Jejkowice
WS68 after 3 yers
« on: June 12, 2025, 03:55:25 AM »
3 years of use of the Ecowitt WS68 sensor. Placed outside since purchase, no battery change so far. The photo shows what the anemometer bracket looks like. The top layer has almost no black paint, just bare aluminum. I wonder how this affects the sensor's solar readings.
For comparison, an 11-year-old Davis anemometer.
Ecowitt, you'll invest in better paint.
Offline R.Sidetrack
Re: WS68 after 3 yers
« Reply #1 on: June 12, 2025, 08:53:53 AM »
I too have a WS68. Mine has been installed since 2020 (5 years), still on the original batteries, and I have had no reason to even set up a ladder to get a closer look at it. Working well!
FYI, if the images in the post above look funny (sideways), for me, once I click on them they turn 90 degrees and take a 'normal' orientation. :)
Graham
--- Variety of 'discrete' Ecowitt devices; CumulusMX on Raspberry Pi4 ---
Offline Gyvate
« Reply #2 on: June 12, 2025, 09:03:31 AM »
before you ask for better paint you will first have to establish if and how much (whether beyond the specified accuracy tolerance) impact there really is.
For that you might need a new one put close to the old one and compare the readings .... 8-)
Looking at the potential reflecting surface this might not be worth the effort. ;)
WS2350 1.7.0,GW1000 1.7.7,WH2650 WiFi 1.7.7,GW1100 2.3.7,GW1200 1.3.4,GW2000 3.2.1,GW3000 1.0.3,HP2550 2.0.1,5.1.9; HP3500 1.7.2,WS3800 1.3.4, WS3910 1.3.4, WN1910 1.2.4,WN1820/WN1980 1.3.5;
Ecowitt WS90, WS85, WS80, WS68, WS69, WN30, WH31,WH31-EP, WH32,WH32-EP, WH32B/WN32P, WN34D,L,S,  WN35,WH40, WH41[PM2.5], WH45, WH46D, WH51, WH55, WH57, LDS01
Blake-Larsen Sun Recorder - RPi4/weewx 4.10.2/CumulusMX 4063/MeteobridgePro 6.1,Meteobridge RPi4B-2GB,MB VM
Barani Meteoshield Pro,MetSpecRad02,SMarTCELLino;Dracal BAR20
WIKI https://meshka.eu/Ecowitt/dokuwiki
Offline Platokidd
  • top side land of Lincoln
« Reply #3 on: June 13, 2025, 06:04:42 AM »
My WS68 looks about the same. Thought about adding some black paint to cover the fade.
Plato Center Weather
Ambient
1-WS-2000 1-WS-2902A 1-WS40/RAIN 1-WH31L
1-METEOBRIDGE 1-SRX100LX
ECOWITT
1-HP2550 2-HP2560 1-GW2000
1-WS3900 1-GW3000 1-GW1100
1-WS68 1-WS80 1-WH32EP 10-WH31 2-WH40BH
1-HP10 1-WH45 1-WH46 4-WH55
1-WN30 1-WH41 6-WH51
1-DAVIS 7714
1-STRATUS
1-Fisher Barometer 1436R-22
1-Starpath Baro
PWS at 2 locations.
And Zelda The Storm Dog
Uploading to: CWOP, AWN, Ecowitt.net, Weather Underground, PWSweather.com, AWEKAS, Windy.com, WOW, MeteoMap.Cloud.
