Author Topic: Ambient Weather WS-5000 restrict reporting sensor  (Read 401 times)
Offline jxnweather
« on: May 24, 2023, 09:09:11 AM »
I just setup a WS-5000 and seem to have it working and uploading data to the ambientweather.net as well as weather underground.   I have an indoor temperature sensor and noticed that this data is also reported/uploaded to the server.   Since this is irrelevant to the "public" I want to allow the temp/humidity to show on my indoor console but not upload it to the server.  I found a way to disable the sensor, but then it will not report on the indoor console.  Is this possible?
thanks
Online Rover1822
Re: Ambient Weather WS-5000 restrict reporting sensor
« Reply #1 on: May 24, 2023, 10:14:13 AM »
thanks
By Default your internal/indoor and other sensors are not shown to the public
see "Only your Outdoor Data is shared from your dashboard. To share your indoor and other sensor data as well click here" under the share settings
Also, logout out of your Ambient site and just go to as though you are public, you will notice the sensors are not there
Edit: To find this setting select devices, then the green arrow next to your device.
« Last Edit: May 24, 2023, 10:21:27 AM by Rover1822 »
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline jxnweather
« Reply #2 on: June 12, 2023, 10:56:07 AM »
Thanks, fixed!
