Author Topic: HP2550 Pantech edit rain fall  (Read 251 times)
Offline drelix
« on: February 06, 2023, 03:15:41 AM »
I was cleaning out the rain catcher and it detected rain is there anyway to remove it or edit it to 0 for the day?
Online olicat
    • FOSHKplugin
Re: HP2550 Pantech edit rain fall
« Reply #1 on: February 06, 2023, 03:24:53 AM »
Hi!
This should be no problem.
You can change this directly on the console:
Gear wheel (rightmost button)
Gear wheel (penultimate key)
Then with the cursor key 4 times up and with the magnifying glass- modify the point Daily Rain.
As a picture story:
It is conceivable that your menu navigation does not correspond to the one shown here. In this case, you should consider a firmware update.
Good luck!
Oliver
Offline drelix
« Reply #2 on: February 06, 2023, 04:11:14 AM »
Can you dumb this down for me lol I don't quite understand what you mean
Online olicat
    • FOSHKplugin
« Reply #3 on: February 06, 2023, 04:53:11 AM »
Hi!
Please forgive me for being short.
I have revised the post.
Oliver
Offline kheller2
« Reply #4 on: February 06, 2023, 11:52:34 AM »
You can edit the totals as reported on the HP2550 display.
This will not change data that was sent to a weather service.
Does anyone know how this will be reflected in the the data that is logged to an SD card?
Ambient Arrays: WH65B
Ecowitt: HP2551BU, GW1000B(dead), GW1100B(2), GW2000B
Ecowitt Sensors: WH51, WN34BL, WN34(2), WH31, WH41, WH40
Offline Gyvate
« Reply #5 on: February 06, 2023, 12:49:46 PM »
you can check this yourself, can't you ? - change one value and look it up after 5 minutes ...
(have to take out the SD card for this of course to read the data written 8-) )
You can change it back in both console and SD card (CSV file)
Online olicat
    • FOSHKplugin
« Reply #6 on: February 06, 2023, 12:55:05 PM »
Hi!
I have never tried this, but I would firmly assume that all current values at the time are also written to the CSV. So record by record.
That means:
If you have a daily value for rain of 12.3 at 18:30 and set it to 0 at 18:31, the CSV should show 12.3 at 18:30 and 0 at 18:31. At least if the storage interval is 1 minute. Otherwise, the update in the CSV only takes place at the respective interval. With the next record.
Values that have already been written are of course no longer adjusted.
Oliver
Offline kheller2
« Reply #7 on: February 06, 2023, 02:15:31 PM »
Yes.. yes I could.  But before I go doing that .. I wondered if anyone already KNEW what would happen.  I'm not trying to get out of work, just trying to avoid duplicate work.   [tup]
Offline Gyvate
« Reply #8 on: February 06, 2023, 04:58:27 PM »
the data saved into the basic sensor csv file is:
Time,Indoor Temperature(℃),Indoor Humidity(%),Outdoor Temperature(℃),Outdoor Humidity(%),Dew Point(℃),
Feels Like (℃),Wind(km/h),Gust(km/h),Wind Direction(°),ABS Pressure(hpa),REL Pressure(hpa),Solar Rad.(w/m2),UVI,
Hourly Rain(mm),Event Rain(mm),Daily Rain(mm),Weekly Rain(mm),Monthly Rain(mm),Yearly Rain(mm)
(possibly with different units depending on your console settings)
=> the next record written after a change of the rain values will contain the new changed values
