Author Topic: WS80 offline after firmware update 1.2.4  (Read 248 times)
Offline Rocketman
« on: February 06, 2023, 03:04:56 AM »
First firmware update for me , anyway all went well but I had trouble getting the station back online to the HP2551 console .
After the update the blue LED was flashing at a fast rate and wouldn’t go back online . I tried to re-register the station but no luck .I waited for the super cap to run out and removed batteries and re- installed etc and finally got the bugger online  :oops:
Is there a graceful way to do the update with a HP2551 console ?
HP2550 console 1.8.7 firmware  , WS80 weather station , WH57 lightning sensor , WH40 rain gauge , WH51 soil moisture sensor , GX1100 gateway 2.2.1 firmware
Offline olicat
    • FOSHKplugin
Re: WS80 offline after firmware update 1.2.4
« Reply #1 on: February 06, 2023, 03:22:24 AM »
Hi!
With this approach, I have successfully updated the WS90 several times.
The procedure should be transferable 1:1 to the WS80:
mini howto updating the WS90 sensor
1. plug in USB cable
2. reset WS90 device (left button on WS90)
3. start DfuSeDemo.exe
4. choose upload file (middle button in the lower area)
5. mark "Verify after download"
6. start Upgrade (button)
7. leave DFU mode (button)
8. unplug USB cable
9. reset WS90 device (left button on WS90)
Especially point 7 and point 9 are often forgotten and therefore lead to problems.
But I don't have a WS80 here and on the HP2551C I have the WS90 disabled. So it might look different there.
Oliver
Offline Rocketman
« Reply #2 on: February 06, 2023, 03:35:03 AM »
thanks Olicat ,
In the instructions it tells you to reset the station after you connect the cable - that doesn’t seem to do anything as you already connected (check under devices usb )
The only thing I didn’t do was reset the station when finished
Offline hiljo
    • Weerstation Marsdijk
« Reply #3 on: February 06, 2023, 04:14:18 PM »
That could very well be the problem. Always reset the unit after an upgrade, and check if the led flashes every 8 seconds or so.
Ecowitt HP2550C v1.8.7
GW2000 v2.2.2
Beta WittBoy WS90 v1.3.0
3x WH31, WH32, WH40, WH41, WH57
WN34L, 2x WH51, WN35
Dutch translator for Ecowitt.
https://www.weerstationmarsdijk.nl/
Offline Rocketman
« Reply #4 on: February 06, 2023, 06:12:17 PM »
I've done this multiple times ( even rollback the firmware 1.2.2 ) same result
Now I know to reset unit after the upgrade
the support instruction should be re-wriitten this would make it easier to follow
