Author Topic: Ecowitt 2553 leak sensor icon without leak sensor?  (Read 195 times)
Offline stratus13
    • My PWS
« on: February 03, 2023, 11:51:49 AM »
Good day!
For a week now the leak sensor #4 light is turned on on my 2553 display.. the problem is.. I don't have leak sensor hooked-up?!?! Is it a firmware problem? Any of you have encountered the same issue?
Thanks!
Stratus13
PS: -25°C Today in Montreal, this is chilly ;)
Ecowitt HP 2553
WU: IQUEBECM21
Offline Platokidd
  • top side land of Lincoln
Re: Ecowitt 2553 leak sensor icon without leak sensor?
« Reply #1 on: February 03, 2023, 12:18:10 PM »
Try disabling the sensors.?
Ambient
2- WS-2000 2-WS-2902A ARRAYS 1-CONSOLE 2-WH40-RAIN 1-WH31L 1-METEOBRIDGE 2-PM2.5(WH42B)
3-WH-31E 1-SRX100LX 1-WH31SM
ECOWITT
3-HP2552 1-HP2562 1-WH51 10-WH31-2-WH45-3-WH55
5-WH51 1-WH32EP 1-WN30 1-WH41
2-GW2000 2-GW1100
1-HP10
1-Davis 7714
1-Stratus
Offline BoDuke
  • Ambient Weather, Ecowitt, WeeWX, Custom PHP
« Reply #2 on: February 03, 2023, 12:18:36 PM »
Once in a while, Ecowitt/Fine Offset gateways and consoles act as if they get a spurious radio transmission that makes them think there's a sensor within range.  The recommended solution is to disable any unused sensors.  You may have missed the following advice in the MUST READ - Fine Offset Clone Models,sensor compatibility,firmware + other info topic:
It is generally GOOD PRACTICE to actively DISABLE all sensors you do not use with your console (HP2550, GW1x00, WH2650) in the sensorsID section of your console or WS View Plus app in order to avoid wrong registrations. Do not leave the sensor ID entry in "learning" mode.
Hope this helps!
Offline Rover1822
« Reply #3 on: February 03, 2023, 02:03:33 PM »
It is not uncommon now, to pick up someone else's sensor. So as previous poster suggested, disable it on your console, along with anything else you are not using.
When it becomes time to add a sensor, re-enable for whatever sensor you are adding.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
