Author Topic: HP2551 console via USB port  (Read 214 times)
Offline Rocketman
« on: January 30, 2023, 09:05:51 PM »
Anyone tried to access the HP2551 console via the USB port ?
Can you get to the SD card slot ?
HP2550 console 1.8.7 firmware  , WS80 weather station , WH57 lightning sensor , WH40 rain gauge , WH51 soil moisture sensor , GX1100 gateway 2.2.1 firmware
Offline olicat
    • FOSHKplugin
Re: HP2551 console via USB port
« Reply #1 on: January 31, 2023, 01:39:42 AM »
Hi!
Yes, both under Windows and Linux.
The port reports itself as a joystick:
Feb 22 11:49:41 oli-ubuntu2 kernel: [6131345.090326] usb 2-1.3: new high-speed USB device number 18 using ehci-pci
Feb 22 11:49:41 oli-ubuntu2 kernel: [6131345.197635] usb 2-1.3: New USB device found, idVendor=1b3f, idProduct=9487
Feb 22 11:49:41 oli-ubuntu2 kernel: [6131345.197641] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Feb 22 11:49:41 oli-ubuntu2 kernel: [6131345.197645] usb 2-1.3: Product: GENERAL - JoyStic
Feb 22 11:49:41 oli-ubuntu2 kernel: [6131345.197649] usb 2-1.3: Manufacturer: GENERAL
Feb 22 11:49:51 oli-ubuntu2 kernel: [6131355.206437] hid-generic 0003:1B3F:9487.00BB: timeout initializing reports
Feb 22 11:49:51 oli-ubuntu2 kernel: [6131355.206703] hid-generic 0003:1B3F:9487.00BB: hiddev0,hidraw2: USB HID v1.11 Device [GENERAL GENERAL - JoyStic] on usb-0000:00:1d.0-1.3/input0
Feb 22 11:49:51 oli-ubuntu2 mtp-probe: checking bus 2, device 18: "/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3"
Feb 22 11:49:51 oli-ubuntu2 mtp-probe: bus: 2, device: 18 was not an MTP device
lsusb:
Bus 002 Device 018: ID 1b3f:9487 Generalplus Technology Inc.
With on-board means and without specially written software, no communication is possible.
At least it was not possible for me.
The USB port is "for internal use only" - presumably the boot loader can be written via it. The manual for the HP2560C now also says: for firmware updates.
I'm pretty sure that you can't access the data on the SD card via this port. As often as I have expressed this wish, Ecowitt would have implemented this useful function long ago.
In any case, this is a function that I would like to see in the future successor model. If you think so too, please express your wish to Ecowitt.
Oliver
Offline kheller2
« Reply #2 on: January 31, 2023, 10:19:06 PM »
It’s directly wired to the G+ MCU as I recall from last I took a look at the traces.  I haven’t gotten a G+ development system up and running yet to see what might be possible.
« Last Edit: January 31, 2023, 10:21:02 PM by kheller2 »
Ambient Arrays: WH65B
Ecowitt: HP2551BU, GW1000B(dead), GW1100B(2), GW2000B
Ecowitt Sensors: WH51, WN34BL, WN34(2), WH31, WH41, WH40
