Author Topic: HP2551 console SD card slot  (Read 368 times)
Offline Rocketman
« on: January 29, 2023, 09:50:14 PM »
Currently have 32 GB card in card slot of the HP2251 console . Ive done a backup
Do we have to setup anything else to do this automatically ?
HP2550 console 1.9.3 , WS80 1.2.4 , WH57 lightning sensor , WH40 rain gauge , WH51 soil moisture sensor , GW1100 gateway 2.3.0
Offline Gyvate
Re: HP2551 console SD card slot
« Reply #1 on: January 30, 2023, 03:24:19 PM »
When your SD card (SDHC type) is inserted, the console automatically writes in the set up interval (default 5 minutes) the basic data and extra sensor data (if applicable) into a file each.
Each month a new (set of) file(s) will be created. YYYYMMA.CSV and YYYYMMAllsensors_a.CSV.
If you remove the SD card during a month, after the next insert a new (set of) file(s) will be created YYYYMMB.CSV, YYYYMMAllsensors_B.CSV etc.
Backup files contain the content of the internal storage and only basic sensor data - file name Backup-A.CSV
after each backup the last letter will be increased by 1 - i.e. B, C, D, ...
Backups have to be initiated manually - the history is archived in the set up archiving interval until the disk is full (which might take a couple of years unless you delete them - then even longer)
Backups will be a maximum of 16 MB - if the internal storage is full, the oldest record will be overwritten.
Offline Rocketman
« Reply #2 on: January 30, 2023, 04:30:25 PM »
Thanks for the explaination  [tup]
