Author Topic: Ecowitt GW1100 pair  (Read 331 times)
Offline capitani
Ecowitt GW1100 pair
« on: January 22, 2023, 12:19:15 PM »
Hello, I am new to this area and to this forum. I have an Ecowitt GW1100 WiFi Gateway and a BRESSER WIFI ClearView Weather Station with 7-in-1. Can I pair the GW1100 with the external sensor of the BRESSER WIFI ClearView Weather Station with 7-in-1.
Offline Rover1822
Re: Ecowitt GW1100 pair
« Reply #1 on: January 22, 2023, 12:28:59 PM »
Can you provide a link to the " BRESSER WIFI ClearView Weather Station with 7-in-1" , I did a search on the prominent post (kudos to Gyvate for maintaining it,  with the "Must Read" as it should be)  at https://www.wxforum.net/index.php?topic=40730.0, and for "Bresser" could not find anything
So, please, provide a link.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline capitani
« Reply #2 on: January 22, 2023, 12:46:47 PM »
Offline Rover1822
« Reply #3 on: January 22, 2023, 12:53:56 PM »
After looking at the unit, this does not appear to be Fine Offset manufactured piece, although similar.
So frankly, no, I do not believe you can use a GW1100, or any Ecowitt / Fine Offset console to read that unit.
For reference , https://www.ecowitt.com/shop/goodsDetail/244 .. this the appearance of the unit that would work. Notice , they are not the same.
Sorry.
« Last Edit: January 22, 2023, 12:58:04 PM by Rover1822 »
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline olicat
    • FOSHKplugin
« Reply #4 on: January 22, 2023, 01:31:40 PM »
Hi!
Bresser stations are made by CCL and not compatible with any device from Fine Offset/Ecowitt.
Oliver
