Author Topic: WS90 Heater question  (Read 234 times)
Offline BadWolf72
« on: January 21, 2023, 12:20:21 PM »
Hi people when i plug the 12V power into the WS90 my array battery voltage drops to 2.04V and i get a low battery warning is this normal? i have left the batteries in the array should i remove them if this is normal?
thank you
Martin
My Weather Station Information All 868Mhz
Ecowitt wittboy                             WS90
Ecowitt weather station                 HP2551
Ecowitt Gateway                           GW1100
Ecowitt Soil Temperature               WN34S
Ecowitt Air Quality Sensor (PM2.5) WH41
Ecowitt Soil Moisture Sensor          WH51
Ecowitt Lightening Sensor              WH57
Online Rover1822
Re: WS90 Heater question
« Reply #1 on: January 21, 2023, 12:27:12 PM »
My understanding is, as mentioned by others, that once you plug in the heater, all of the power for the unit comes from that supply.
The battery and capacitor values then go "wacked" and are not to be used. Something the manufacturer is aware of. So in short, the battery, and cap values , become useless when plugged in.
I am recounting other's posts , and not my own experience. But you can find this all over the place in previous posts
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline BadWolf72
« Reply #2 on: January 21, 2023, 12:55:49 PM »
thank you for replying rover1822 if its normal then its good and if ecowitt can do something to correct it through a firmware upgrade at some point that would be nice.... i was just worried i did something wrong but once again thank you.
Martin
Offline wsNoordbergum
    • wsNoordbergum
« Reply #3 on: January 22, 2023, 11:41:21 AM »
The battery voltage reading when external powered is of no use, if no batteries installed with external power, the capacitor does charge normally with sunlight.
Would be better if the battery reading would show up as with normal battery operation, but I guess this is a hardware related issue and not easy solvable with a firmware upgrade.
I had still a 2.25 volt battery reading on the app without batteries installed!
Davis Vantage Pro 2 UV/Solar
Meteobridge nano SD
Ecowitt WS90 WH40 WH31 WH57 GW2000 HP2550_c
CumulusMX/raspberry Pi 4b
Online Rover1822
« Reply #4 on: January 22, 2023, 11:50:32 AM »
I think the consoles still send out the battery values, even if , there is not a sensor sending data. I'm not sure on this, but there is a bit of sense on doing this. For instance if you have a sensor go off line because of a low battery situation, the battery status may hang around to give you that clue why, if it was a low battery situation.
Again, this is my conjecture. I do know that it hangs around on Ecowitt.net for like a week, even if you have removed the sensor.  I'm just making a guess that the console is still sending it. It could , of course just be the web site. I never did look at wsview to see what happens, I spend most of my time checking Ecowitt.net
maybe someone else knows
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
