Author Topic: WS90 Haptic Array Cap....  (Read 958 times)
Offline BadWolf72
« on: January 20, 2023, 07:44:18 AM »
Hi people a quick question i got the WS90 a few days ago now when i first powered it on the array capacitor was at 4.2V and now its down to about 2.5V (see pics) and we have had sunny days is the 2.5V correct operating voltage or is this unit faulty?
Thank you
Martin
My Weather Station Information All 868Mhz
Ecowitt wittboy                             WS90
Ecowitt weather station                 HP2551
Ecowitt Gateway                           GW1100
Ecowitt Soil Temperature               WN34S
Ecowitt Air Quality Sensor (PM2.5) WH41
Ecowitt Soil Moisture Sensor          WH51
Ecowitt Lightening Sensor              WH57
Online Rover1822
Re: WS90 Haptic Array Cap....
« Reply #1 on: January 20, 2023, 08:01:08 AM »
Are you powering the unit with heater/power cable as well?
Can you also provide your solar data from the unit ?
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline BadWolf72
« Reply #2 on: January 20, 2023, 08:09:34 AM »
Thank you for replying Rover1822..
No power to the heater pad not set that up yet and i have attached pics you requested
Thank You
Martin
Online Rover1822
« Reply #3 on: January 20, 2023, 08:23:01 AM »
I'm used to w/m^2 , but even then, it is concerning that we are not seeing a bump in the haptic cap voltage.
I'd let it go for a few more days. Yes, I do find your values low day over day.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Online Rover1822
« Reply #4 on: January 20, 2023, 08:44:39 AM »
For reference, here is one of mine, on a partially sunny day
Now, if there had been a string of cloudy days before this, then it can a few days for me to end up at 5.3V
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline BadWolf72
« Reply #5 on: January 20, 2023, 09:26:48 AM »
OK thank you Rover1822 i think i found the problem the array had a couple of mm of ice over it the after removing it and only been 30 mins the solar is up to 1.3k and the cap voltage is already up to 3.5v i will monitor it over the next few days ..... if i get the heater working will that stop ice build up on top of the array or is it too far from the heater to do that?
Thank You
Martin
Online Rover1822
« Reply #6 on: January 20, 2023, 09:30:00 AM »
I have no idea on the heater as I don't use one, someone else may know.
Your battery level I also find to be low, from the start, did you use fresh Lithium batteries?  Although that won't matter much if you use the heater cable
« Last Edit: January 20, 2023, 09:37:33 AM by Rover1822 »
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline BadWolf72
« Reply #7 on: January 20, 2023, 09:34:44 AM »
I am using Alkaline batteries at the moment i have some lithium ones on order maybe the cold is slightly effecting the batteries but its only 32f so i would think they should be ok.
Thank You
Martin
Offline KC5JIM
    • KC5JIM Weather
« Reply #8 on: January 21, 2023, 11:15:46 AM »
Thank You
Martin
The heater is not powerful enough to melt ice on the cap.
Offline wsNoordbergum
    • wsNoordbergum
« Reply #9 on: January 22, 2023, 11:18:01 AM »
I had the unit powered with external power source and no batteries inserted.
It charged my supercap up to 5.3 volt yesterday, it was a sunny day.
So the solarpanel will charge the supercap even with external power.
With alkeline batteries and no or little sunshine, my batteries drained within a week from 3 volt to 2.8 volt
Also the supercap did not charge above 3 volts at that time.
Lithium batteries are essential in my opinion.
Davis Vantage Pro 2 UV/Solar
Meteobridge nano SD
Ecowitt WS90 WH40 WH31 WH57 GW2000 HP2550_c
CumulusMX/raspberry Pi 4b
Online Rover1822
« Reply #10 on: January 22, 2023, 11:23:50 AM »
Be interesting to see what happens to your supercap's reported voltage while you have it plugged in. My understanding is that it plays no role when plugged in, for powering the actual circuitry. I agree with the lithium requirement. I guess have to see with cloudy days, on what gets reported.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
