Hi!
Also for the
WS90 is a new firmware available:
v1.3.0. In the meantime, you can also find it on the
sensor page under "MANUAL & SOFTWARE".
Changelog:
- optimize low/no wind speed detection algorithm.
add:
This time, the update package actually does not contain any update instructions. And the corresponding programme dfuse_demo_v3.0.6_setup.exe is also missing. So just the firmware file(s).
Strangely, the older firmware packages are also no longer offered, from which one could use the instructions and the required programme.
The current update therefore requires a version that is already available.
But
here you may download the previous version v1.2.6 with update instructions and with the required software. After installing you should use the WS90_V1.3.0.dfu to update. But I have no idea what to do with the WS90_V1.3.0_0x006C01D0.hex.
edit:
In the meantime, a revised firmware update package v1.3.0 with the necessary software as well as the instructions is available
here.
Oliver
