Author Topic: gw2000 vs. gw1000  (Read 254 times)
Offline Platokidd
  • top side land of Lincoln
gw2000 vs. gw1000
« on: January 10, 2023, 09:12:11 PM »
 What is the temp coded? See attached.
« Last Edit: January 10, 2023, 09:15:39 PM by Platokidd »
Ambient
2- WS-2000 2-WS-2902A ARRAYS 1-CONSOLE 2-WH40-RAIN 1-WH31L 1-METEOBRIDGE 2-PM2.5(WH42B)
3-WH-31E 1-SRX100LX 1-WH31SM
ECOWITT
3-HP2552-WH51 10-WH31-2-WH45-3-WH55
5-WH51 1-WH32EP 1-WN30 1-WH41
2-GW2000 2-GW1100
1-HP10
1-Stratus
Offline Platokidd
Re: gw2000 vs. gw1000
« Reply #1 on: January 11, 2023, 04:48:04 AM »
Here's the answer Ecowitt gave me... #-o say what
Ecowitt
There is special item for Outdoor Temperature, calculating feels like index, dewpoint.
If Outdoor Temperature Coded is false, it would not provide feels like index, dewpoint
« Last Edit: January 11, 2023, 05:04:47 AM by Platokidd »
Ambient
ECOWITT
2-GW2000 2-GW1100
1-HP10
1-Stratus
Offline Platokidd
« Reply #2 on: January 11, 2023, 05:02:54 AM »
The same hold true for the hp2550 and hp2560.....
Ambient
ECOWITT
2-GW2000 2-GW1100
1-HP10
1-Stratus
Online olicat
    • FOSHKplugin
« Reply #3 on: January 11, 2023, 05:58:32 AM »
Hi!
I still don't get it. My HP2551C shows me Feelslike and Dewpoint. This is also true for the GW1100.
So what do they mean? Do you understand?
Oliver
Online broadstairs
« Reply #4 on: January 11, 2023, 06:12:55 AM »
I wonder if they were still attempting to provide feels like and dew point if the outdoor temperature sensor was either not present of not working. I have removed my temp/hum sensor from my WS80 at present while I waited for a replacement from Ecowitt (which has now arrived and is waiting for me to fit it!) and these values show --.- right now. I had not checked before because I don't use this facility much so not sure if there were spurious errors before as I rely on my software for data.
Stuart
Online olicat
    • FOSHKplugin
« Reply #5 on: January 11, 2023, 06:29:55 AM »
Hi!
Yes, but I wouldn't use that as a sales argument, I would fix the firmware accordingly - because calculating T/H-based values without T/H is a bug.
However, the firmware for GW1100 is identical to GW2000 just as the firmware for HP255C and HP2560C is identical.
Why should there be a bug for one of these devices?
Oliver
