Author Topic: View Sainlogic WS3500 data in Cumulus, Weather SmartIP or similar apps  (Read 545 times)
Offline leofe
Greetings everyone, I'm new here.
I live in Portugal and in October 2021 I acquired a weather station that could send data to the internet. I opted for the Sainlogic WS3500, and it has worked very well, with data being sent to Ecowitt, Wunderground, WOW, Weathercloud and Awekas.
However, I've always wanted to visualize this data in a different way, directly on the PC, in applications like Cumulus for example, but unfortunately that possibility doesn't exist, I think.
Today I read a topic on this forum and I had the idea of ​​downloading WeatherSmartIP from the Ecowitt website in an attempt to see if eventually, due to the fact that Sainlogic WS3500 = Froggit WH3000SE, this could work and I could visualize the data in that application.
At the beginning, it appears to me to select an IP address, in my case two appear, but none correspond to the console of my station, even though it is connected to the same WiFi as the console and the WSView Plus application. One of the IP addresses was something similar to the one indicated in the WSView Plus app, and after selecting it, no information appeared on the panel, but the name of the station appeared in the footer (EasyWeather - WIFIxxxx), although with failures sometimes, but I couldn't do more nothing. In the station settings, when I configure the update interval, the message "enter a number" appears, but it ends up failing.
Does anyone know if this is possible?
Waiting for answers.
leofe
Weather station (12/01/2022 - 09/01/2023): https://www.wunderground.com/dashboard/pws/IPARAD25
Weather station (from 09/01/2023): https://www.wunderground.com/dashboard/pws/IPARAD43
Online Rover1822
Re: View Sainlogic WS3500 data in Cumulus, Weather SmartIP or similar apps
« Reply #1 on: December 30, 2022, 02:35:19 PM »
OK, I Tried that app, not impressed and old.
The entries you saw when trying to select one, were actually from the PC you were running from, not the console for the system, and you can't manually enter the IP of your console.
If you then allow the program to open after having selecting something previously (your PC IP) , you can go to system, (wait a minute or so), and it will populate with your console in the list, you can then select that. And it will recognize it.
Unfortunately, it won't display any values, so a total waste of time. Relaunching the app, makes you go through it all again. So again, total waste of time
For PC use, you are better off going to the web page for one of the weather services you are subscribing to.
-Rover
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline Gyvate
« Reply #2 on: December 30, 2022, 03:12:42 PM »
you can use CumulusMX with your console.
You have to use the HTTP(Ecowitt) station type in CMX and configure the custom server of your console ("Customized") in WS View Plus
IP/server: the IP address of your computer running CMX
path:/station/ecowitt
port: 8998
interval: 16
WS2350 1.6.5, GW1000(3) 1.7.6, WH2650 WiFi (2) 1.7.6 (test/backup), GW1100 2.2.3, GW2000(3) 2.2.3, HP2551 1.6.5/1.9.0, WN910 1.2.2;
MeteobridgePro(2)[test,prod] 5.5 Oct 27 2022, 14855 - Blake-Larsen Sun Recorder - RPi4/weewx 4.8.0/CumulusMX 3231/Meteobridge RPi4B-2GB(2886)
Offline Gyvate
« Reply #3 on: December 30, 2022, 03:21:59 PM »
the WH2910 console (Froggit WH3000SE) is not meant to work with WeatherSmartWiFi or WeatherSmartIP - only the WS2320E (Froggit WH4000SE);
the WH2910 console doesn't have an API to be called by WeatherSmartWiFi/IP.
our MUST READ thread would have told you https://www.wxforum.net/index.php?topic=40730.0 (look at the matrix)
But CumulusMX, weewx, Meteobridge can receive data from the WH2910/WH3000SE.
Offline leofe
« Reply #4 on: December 30, 2022, 08:04:43 PM »
port: 8998
interval: 16
Hello again, and thanks for the tip.
I followed the steps you said. I started by downloading Cumulus MX v.3215 (latest version) and copying the folder to the programs folder. I opened the "CumulusMX" executable and then a kind of command prompt opened, which said to put one of those links in the browser, in my case Chrome.
Then a "configuration" opened, and I think I did everything right, even in WSView Plus.
Then, I entered the new link that appeared in the prompt, and then I entered the "page" of my station. Very chic I say!
However, everything appears to zeros, I don't know what I did wrong. I even tried to configure it again but I'm afraid of making the situation worse.
Do you have any idea how to fix it?
leofe
Online PaulMy
« Reply #5 on: December 30, 2022, 08:43:31 PM »
From Cumulus WiKi
There is one place, where you must not store MX, and that is "avoid the 'Program File' hierarchy"
It is suggested to install such as C:\CumulusMX
If you have it reinstalled as advised and used the Config Wizard to do the basic setup, and then a stop and restart, check the C:\CumulusMX\MXdiags file to see if any errors are logged.
Enjoy,
Offline leofe
« Reply #6 on: December 30, 2022, 09:32:14 PM »
From Cumulus WiKi
Enjoy,
Hello again,
After removing the CumulusMX folder from the programs folder and having moved it from the original .zip file to C:/ only, I went back to configuring everything. In the end, I even restarted the PC, but it didn't work again. I went to the folder you indicated and there were some text files, I am attaching the most recent one.
Edit: first file - CMX working, second file - after CMX shutdown
leofe
« Last Edit: December 30, 2022, 09:37:59 PM by leofe »
Online PaulMy
« Reply #7 on: December 30, 2022, 11:16:56 PM »
The MXdiags shows:
2022-12-31 02:23:46.104 Normal running
2022-12-31 02:23:46.336 This Cumulus MX instance is running the latest version
2022-12-31 02:24:00.438 Minimum data set of pressure, temperature, and wind is not available and NoSensorCheck is not enabled. Skip processing
2022-12-31 02:24:16.188 Realtime[0]: Not all data is ready, aborting process
2022-12-31 02:24:46.127 Realtime[1]: Not all data is ready, aborting process
2022-12-31 02:25:00.097 Minimum data set of pressure, temperature, and wind is not available and NoSensorCheck is not enabled. Skip processing
2022-12-31 02:25:16.128 Realtime[2]: Not all data is ready, aborting process
2022-12-31 02:25:46.128 Realtime[3]: Not all data is ready, aborting process
2022-12-31 02:26:00.233 Minimum data set of pressure, temperature, and wind is not available and NoSensorCheck is not enabled. Skip processing
2022-12-31 02:26:16.132 Realtime[4]: Not all data is ready, aborting process
2022-12-31 02:26:46.134 Realtime[5]: Not all data is ready, aborting process
2022-12-31 02:27:00.210 Minimum data set of pressure, temperature, and wind is not available and NoSensorCheck is not enabled. Skip processing
2022-12-31 02:27:16.145 Realtime[6]: Not all data is ready, aborting process
2022-12-31 02:27:46.154 Realtime[7]: Not all data is ready, aborting process
2022-12-31 02:28:00.231 Minimum data set of pressure, temperature, and wind is not available and NoSensorCheck is not enabled. Skip processing
2022-12-31 02:28:16.157 Realtime[8]: Not all data is ready, aborting process
2022-12-31 02:28:46.160 Realtime[9]: Not all data is ready, aborting process
2022-12-31 02:29:00.176 Minimum data set of pressure, temperature, and wind is not available and NoSensorCheck is not enabled. Skip processing
2022-12-31 02:29:16.165 Realtime[10]: Not all data is ready, aborting process
2022-12-31 02:29:46.179 Realtime[11]: Not all data is ready, aborting process
2022-12-31 02:30:00.309 Minimum data set of pressure, temperature, and wind is not available and NoSensorCheck is not enabled. Skip processing
2022-12-31 02:30:16.199 Realtime[12]: Not all data is ready, aborting process
2022-12-31 02:30:46.206 Realtime[13]: Not all data is ready, aborting process
2022-12-31 02:31:00.301 Minimum data set of pressure, temperature, and wind is not available and NoSensorCheck is not enabled. Skip processing
2022-12-31 02:31:16.221 Realtime[14]: Not all data is ready, aborting process
2022-12-31 02:31:46.226 Realtime[15]: Not all data is ready, aborting process
2022-12-31 02:32:00.496 Minimum data set of pressure, temperature, and wind is not available and NoSensorCheck is not enabled. Skip processing
2022-12-31 02:32:16.236 Realtime[16]: Not all data is ready, aborting process
2022-12-31 02:32:46.251 Realtime[17]: Not all data is ready, aborting process
2022-12-31 02:33:00.010 Minimum data set of pressure, temperature, and wind is not available and NoSensorCheck is not enabled. Skip processing
2022-12-31 02:33:16.252 Realtime[18]: Not all data is ready, aborting process
2022-12-31 02:33:46.261 Realtime[19]: Not all data is ready, aborting process
2022-12-31 02:34:00.197 Minimum data set of pressure, temperature, and wind is not available and NoSensorCheck is not enabled. Skip processing
2022-12-31 02:34:16.270 Realtime[20]: Not all data is ready, aborting process
2022-12-31 02:34:46.284 Realtime[21]: Not all data is ready, aborting process
2022-12-31 02:34:47.597 Exiting system due to external: Close Main Window
2022-12-31 02:34:47.603 Cumulus closing
2022-12-31 02:34:47.603 Stopping timers
2022-12-31 02:34:47.603 Stopping extra sensors...
2022-12-31 02:34:47.604 Extra sensors stopped
2022-12-31 02:34:47.604 Stopping station...
2022-12-31 02:34:47.604 HTTP Station (Ecowitt) Stopped
2022-12-31 02:34:47.605 Station stopped
2022-12-31 02:34:47.605 No data read this session, today.ini not written
2022-12-31 02:34:47.605 Station shutdown complete
2022-12-31 02:34:48.116 Cumulus has shutdown
If it is just one or more of the sensors not being available you can tick [Sensor check] in Station settings > Common Options and CumulusMX would then continue, but likely that is not your issue.
I am not familiar with your station but Gyvate indicated it should work and for that you will need to do the settings in the WS View App so that CumulusMX can get access to it
you can use CumulusMX with your console.You have to use the HTTP(Ecowitt) station type in CMX and configure the custom server of your console ("Customized") in WS View Plus
port: 8998
interval: 16
Enjoy,
Offline Gyvate
« Reply #8 on: December 31, 2022, 03:18:11 AM »
looks like either a network, a console setup or combined issue
1. can you post a picture of your WS View page showing the customized settings ? More --> Weather Services --> Customized
2. make sure the entries are made EXACTLY as mentioned earlier (no http:// etc in front of the IP address)
3. make sure the IP address chosen is the IP address of your computer on which CMX runs
4. the path is /station/ecowitt  (no closing "/" or other character)
5. the protocol type is Ecowitt
6.  save your WS View Plus settings for the customized server: top right "save" --> wait for a "success" message to appear
7. usually, when you start CMX for the 1st time on a Windows computer, a message pops up asking for firewall permission
make sure you don't ignore the message and confirm it positively - the message will no more appear later !!!
Sometimes the message can be hidden - check your Windows task bar and all open Windows (ALT+TAB)
You will have to re-install CMX and start it again for the firewall message to appear again - best inside a console window
WINDOWS+R ---> cmd --> ENTER ---> cd \CumulusMX ---> CumulusMX
8. can you ping your console ?
WINDOWS+R --> cmd ---> ENTER --> ping xxx.xxx.xxx.xxx (IP address of your console from your router IP address list)
In the WS View Plus device list you will also see the IP of your console.
WINDOWS means the Windows key on your keyboard (with the Windows symbol on it)
« Last Edit: December 31, 2022, 03:23:47 AM by Gyvate »
Offline mcrossley
    • Wilmslow Astro
« Reply #9 on: December 31, 2022, 06:20:04 AM »
Windows firewall, add a rule to allow inbound TCP on port 8998
Offline leofe
« Reply #10 on: December 31, 2022, 09:31:06 AM »
Hello again Gyvate,
This is a print of my WSView app. The IP Adress is hidden but it's the same of my PC where I run CumulusMX.
leofe
Offline leofe
« Reply #11 on: December 31, 2022, 11:39:06 AM »
Hello again Gyvate,
leofe
Hello again,
I did everything again, but the problem persists. This time the firewall warning did not appear, I think because I previously allowed access (private networks). I took some prints of the process, even the page where only zeros appear, and I even took a picture of the console ping, as you can see in the attachment.
I'm getting a little tired of this already. I'm already thinking about giving up.
Any errors you find, please let me know.
leofe
Offline mcrossley
    • Wilmslow Astro
« Reply #12 on: December 31, 2022, 11:52:46 AM »
A quick test for your Windows Firewall...
with CMX running on your computer...
Use a phone/tablet/other computer connected to your local network and try and open the CMX dashboard...
http://<ip_address_of_cmx_computer>:8998/
If that works your firewall is configured correctly, if not then you need to add a new in-bound rule to allow TCP on port 8998.
Offline leofe
« Reply #13 on: December 31, 2022, 01:06:41 PM »
It already works! Thanks mcrossley for the precious tip and to everyone else who wrote in this thread to help.  [tup]
I checked and indeed the dashboard did not appear on my phone. There I looked for the Firewall, I added this rule, and the first time it didn't work. I noticed that there were other rules associated with CumulusMX. I deleted them all and created again, and it finally worked!
To continue working, my PC must always remain connected to the same network, right? Eventually if you need to take it somewhere else, it will stop working, right?
Now that it works, let's see what the next few hours will be like, there's a lot of rain and a lot of wind coming, even my district - Vila Real will be under red warning from midnight (see www.ipma.pt).
Again, thank you very much for your patience.
I wish you all a happy and prosperous New Year 2023!
leofe
Offline Gyvate
« Reply #14 on: December 31, 2022, 06:48:55 PM »
when you post data to ecowitt.net, CMX can download the missing data if you switch off your PC for a certain time.
For this to work to need to create an APP key and an API key in your Ecowitt account and enter them into the CMX setup.
Your CMX logging may be by the minute, the ecowitt.net download will be in a five minute interval as this is what is stored at ecowitt.net; but at least your gaps created by your PC being disconnected or switched off will be filled.
Offline leofe
« Reply #15 on: January 10, 2023, 04:56:53 PM »
Greetings everyone,
My weather station sometimes indicates that the wind speed is zero. However, the wind direction changes even though the wind speed remains at zero. Does anyone know what could happen?
leofe
Online PaulMy
« Reply #16 on: January 10, 2023, 05:22:49 PM »
Sorry, I don't know why it would happen.  Possibly you can check your \CumulusMX\Diags files and see if there is anything logged about what is being received from the station when that happens.  You can also enable "Use zero for current bearing if speed is zero".  in Cumulus Station settings > Common Options to stop an invalid direction:
[  ]  Use bearing zero when calm
Enjoy,
Offline leofe
« Reply #17 on: January 10, 2023, 06:43:01 PM »
Enjoy,
Hello again, I didn't make myself understood well, or maybe I didn't put it in the right topic, I apologize. The problem I report has to do with my station and not with Cumulus. It's something that's been happening to me for a long time, and it's visible in Wunderground's graphics for example. The direction changes, in degrees, but the velocity remains at zero. I already created a possible theory. Perhaps the console only detects speeds above 0.4 km/h, which is the minimum speed. Below that, a light breeze can perhaps move the wind vane, but it is not detectable.
leofe
Offline alanb
« Reply #18 on: January 10, 2023, 11:54:09 PM »
Maybe a light variable breeze is enough to swing the weather vane around but not strong enough to spin the wind cups enough to register wind speed.
I have an Ambient Weather WS-2000 which I think is the same basic array as your Sain WS3500. One thing I noticed is that during a extended period (couple of hours or more) of zero wind speed, my wind direction almost always eventually migrates to an easterly direction. I thought this might be caused if the vane isn't perfectly balanced and my array might not be precisely level. I have checked the level bubble multiple times and it is about as dead center as possible, so I don't know why there is a bias to east during periods of no wind.
Alan - Ambient WS-2000, WH31E x4, WH31L
