This is not going too well.
Weather Display first. I get the following error
230 OK. Current restricted directory is /
TYPE I
200 TYPE is now 8-bit binary
Change to remote Dir /home/rosalind/mad-weather.com
CWD /home/rosalind/mad-weather.com
550 Can't change directory to /home/rosalind/mad-weather.com: No such file or
directory
141: FTP protocol error: 550 Can't change directory to /home/rosalind/mad-
weather.com: No such file or directory
The clientraw.txt files etc are being loaded as per schedule
I can't work out how much is and isn't loading into the /pwsWD folder
Weewx I get a similar message and the same 553 error, can't open that file or no such file or directory.
iSpy running as an agent also gives the same error.
I kept the directory structure the same when I transferred files across, so I only had to change the login details. I also used the server address not mad-weather.com, which I do anyway. I know the login details are correct as the clientraw files are there.
Anybody able to shed any light on what is going on here. I have a ticket open with the hosting but I think they are scratching their heads as well.
Rosalind
