Author Topic: new firmware version for GW1100/GW2000: V2.1.9  (Read 1016 times)
Offline olicat
  • GWxx00, HPx5x1C, WN1900C, WN1980C & WS3xx0C
    • FOSHKplugin
« on: September 27, 2022, 12:51:57 AM »
Hi!
There's a new firmware version V2.1.9 available for the GW1100 and GW2000.
Use the current WSView Plus app or the web interface of the GW1100/GW2000 ("Device Setting") to update.
Changelog for V2.1.9:
1.Optimize exception handling of RF reception
2.Fix some display problems
3.Supports the upload of leaf moisture sensor data
Oliver
Offline Gyvate
Re: new firmware version for GW1100/GW2000: V2.1.9
« Reply #1 on: September 27, 2022, 02:09:07 AM »
I think the following is worth to be noted:
3.Supports the upload of leaf moisture sensor data is meant for the WH2682 mode of the GW2000 - the GW2000 in its normal "edition" could already upload WN35 data earlier.
the WH2682 as a physical console/gateway is the Ambient ObserverIP 2.0 - it will show this name (WH2682) in its WebUI
However, a GW1100 and GW2000 can also be put into the WH2682 mode if the wires for the internal T/H sensors are removed  8-)
the WebUI of a GW1100/GW2000 and a WH2682/ObserverIP2.0 is the same - with the difference that a real ObserverIP2.0 can only display all available Ambient sensors and not all Ecowitt sensors.
A GW1100/GW2000 in WH2682 mode however can display of course all Ecowitt and Ambient sensors.
MeteobridgePro(2)[test,prod] 5.8 Mar 01 2024, 15185 - Blake-Larsen Sun Recorder - RPi4/weewx 4.8.0/4.10.2/CumulusMX 3283/Meteobridge RPi4B-2GB,
Barani Meteoshield Pro, MetSpec Rad02
WIKI http://meshka.eu/Ecowitt/dokuwiki
Offline broadstairs
« Reply #2 on: September 27, 2022, 06:26:14 AM »
Just installed this and will see how it goes. All OK so far. Interesting about the RF reception as I reported my problem to Ecowitt where I was occasionally missing a rain tip on the GW1100, although it also happened on the GW1000 so wonder if that will get an update as well.
Stuart
Offline Gyvate
« Reply #3 on: September 27, 2022, 06:29:43 AM »
I have often a 0.1 mm rain tip difference between my HP2550 console and my WN1910 console (GW1000 API) - and it shifts between the two ...
Offline mcrossley
    • Wilmslow Astro
« Reply #4 on: September 27, 2022, 06:39:02 AM »
I still think the rain discrepancies are rounding errors in the Ecowitt code rather than anything else. One receiver could miss transmissions for a whole day and the counts should still match once it does receive a message.
Offline broadstairs
« Reply #5 on: September 27, 2022, 06:49:20 AM »
Yes but the issue is that it misses a single tip but continues to receive all the other tips and never corrects.
Stuart
Offline giusCB
  • www.turismometeo.it
« Reply #6 on: September 27, 2022, 07:32:18 AM »
" exception handling " What does this mean ?
www.turismometeo.it
Offline mcrossley
    • Wilmslow Astro
« Reply #7 on: September 27, 2022, 07:46:09 AM »
My point is because of the way they work they cannot miss a tip. They may miss transmissions but the tips are not lost.
Offline Gyvate
« Reply #8 on: September 27, 2022, 11:44:56 AM »
I guess it means situations where there are issues (e.g. connection drops) with the connection between console and sensors - how this is handled.
Usually, in a programming context, exception handling means dealing with situations which are outside the "normal", usual and expected during proper functioning.
Such an exception may be the loss of the RF connection (in the sense that no packets or no processable packets are received in a certain period of time).
Offline kheller2
« Reply #9 on: September 27, 2022, 05:32:17 PM »
So this sort of implies Ambient will be getting leaf moisture sensors?
And ... are you saying that the unit behaves differently if you remove the T/H sensors and "becomes" a WH2682 that then needs a WH32B for T/H?
Ambient Arrays: WH65B
Ecowitt: HP2551BU, GW1000B(dead), GW1100B(2), GW2000B
Ecowitt Sensors: WH51, WN34BL, WN34(2), WH31, WH41, WH40
Offline Gyvate
« Reply #10 on: September 27, 2022, 06:28:41 PM »
If you remove the T/H sensor from a GW1100 or GW2000, it becomes a functional WH2682, the firmware switches into WH2682 mode, and it will need/be able to connect a WH32B - correct
The WH32B will override the internal pressure sensor.
The fact that the WH2682/ObserverIP 2.0 now supports the upload of Leaf Wetness sensors most likely means that Ambient will soon come up with a WH31something for their WN35. I don't think Ecowitt implemented that just for people who remove the T/H sensor from a GW1100/GW2000 ... \:D/ - which average user would have that knowledge and apply it ... :roll:
Offline hiljo
    • Weerstation Hattem
« Reply #11 on: October 01, 2022, 08:59:42 PM »
Is it possible to disable the immediate upload after a lightning strike somewhere? Does anyone know? Thanks!
Ecowitt HP2550C v1.9.3
2x GW2000 v3.1.1
WittBoy WS90 v1.3.8
Smart Sensors (WFC01 & AC1100) beta tester
3x WH31, WH32, WH40, WH41, WH57
WN34L, 2x WH51, WN35, WN34D
Dutch translator for Ecowitt.
https://www.weerstationhattem.nl/
Offline Gyvate
« Reply #12 on: October 02, 2022, 02:24:56 AM »
As far as I know it is hardcoded in the WiFi firmware. No selectable option.
Why would you want to disable the immediate upload ?
« Last Edit: October 02, 2022, 02:26:53 AM by Gyvate »
Offline hiljo
« Reply #13 on: October 02, 2022, 05:05:04 AM »
My custom upload cannot handle a lot of uploads at a short interval. I've set it now at every 5 minutes. So if there are more uploads then once a every 5 minutes, my calculations go wrong  #-o
2x GW2000 v3.1.1
WittBoy WS90 v1.3.8
Offline Autofill
« Reply #14 on: October 04, 2022, 12:18:37 AM »
Interesting. My GW2000 is still on 2.1.8 and says that is the latest version. Hmmm..
Auto update is enabled.
Ecowitt WH2320-E
Ecowitt HP2551-C (SOLD - replaced with Home Assistant Fully Kiosk FireTab HD10)
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH41 (Honeywell-based USB/Supercap modified)
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Ecowitt Wittboy running on 12VDC  solar power
Offline Gyvate
« Reply #15 on: October 04, 2022, 05:16:25 AM »
maybe you need to refresh the interface - "logout" (call IP address only in the browser)/login
and then check manually for firmware upgrade
