If someone goes with an off the shelf USB battery/solar solution, it will be at 5 volts. I mean you could rig your own solution , but that would be an increased effort.
I get it on the RF noise, I have an expensive POE PTZ security camera that completely trashes my VHF reception, so bad , I got rid of the camera.
But, if the user is not running shortwave/vhf receivers, etc , probably not an issue.
For measuring current I have a USB meter that just slaps in line (they are fairly cheap) , but I don't have the HP10 to measure lol.
Edit: We know they make off the shelf solar chargers for other security cams like an Arlo or similar, but those cams usually have an onboard battery supply, so it comes down to also sizing a small battery bank and balancing it vs solar so the cam doesn't lose power over an extended period. The security cams, like the Arlo, Ring, Nest etc that do run on batteries , are usually motion activated which takes little power as opposed to something that is continuous or frequently transmitting images which is were the power draw occurs. I have a front security camera that I need to run off the equivalent of a car battery and I'm using a 125W solar panel. But that camera is sending streams continuous and the battery was sized to get me through a week or 2 of low charging. I also have a tendency to overscale my builds so I don't have to worry about it LOL
