Author Topic: WH40 Reporting Double Amount  (Read 281 times)
Offline ajay
« on: September 10, 2022, 11:09:09 AM »
This is crazy. I've been using the WH40 for well over a year and have it calibrated to usually be within a couple of hundredths of an inch compared to a Stratus rain gauge. This morning however it seems to be recording double the actual amount. Has anyone else ever experienced this? I guess I'll pull the battery and power cycle the sucker.
Online Rover1822
Re: WH40 Reporting Double Amount
« Reply #1 on: September 10, 2022, 11:32:05 AM »
I would also check / clean your bucket as needed
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline ajay
« Reply #2 on: September 10, 2022, 06:36:45 PM »
That was it. The tipping spoon was 1/2 filled with crud which has me scratching my head. I had just cleaned the entire unit about 3 weeks ago and there was only a little bit of sediment at that time and that accumulation was over a 6-month period.
When I first installed the WH40 I built a splash guard with bird spikes out of copper flashing and #12 gauge electrical wire. This kept the birds from perching on it but evidently either the birds got creative in their bombing technique or something else got in there -- possibly insects.
I cleaned out the tipping spoon and now I'll wait for another rain to see if it's back to being accurate. I found with my splash guard and a multiplier of 1.05, my readings were usually spot-on or at least within a few hundredths of an inch.
I guess I will have to inspect the tipping spoon more often from here on out.
I've attached a pic of my setup. It's ugly looking but effective (usually).
Offline Gyvate
« Reply #3 on: September 11, 2022, 04:34:37 AM »
that "splash guard" has been discussed several times here in the forum - new technology: 3-D print - but the idea is the same - and it works quite well
e.g. https://www.wxforum.net/index.php?topic=44374.0
https://www.wxforum.net/index.php?topic=39166.0
