Author Topic: WU maps not updating again  (Read 1481 times)
Offline weatherdoc
    • Willowsford Farm Weather
Re: WU maps not updating again
« Reply #1 on: August 16, 2022, 07:23:28 AM »
The couple I use on my website are updating and current:
https://novawx.dscloud.me/ (satellite loop bottom right)
https://novawx.dscloud.me/wxradarmosaic-wu-ma.php (Mid-Atlantic Weather Radar Mosaic Reflectivity Loop)
I no longer use the WU radar products that you have on your homepage that are not working, so maybe it's just that product that WU has killed?
Offline weatherdoc
« Reply #2 on: August 16, 2022, 07:24:52 AM »
And 30 seconds after I posted my reply, I see the WU radar is once again displaying on your homepage! Must have been a temporary issue with WU.
« Reply #3 on: August 16, 2022, 08:23:09 AM »
I still see me as old.
https://bsmweather.org/allinone.php
tried ctrl/F5 as a reset.  still old, #-o
« Reply #4 on: August 16, 2022, 09:34:23 AM »
Yes, they seem to have stopped generating the old format radar images around 9-Aug-2022.  Time to take that script out of the menu.
« Reply #5 on: August 16, 2022, 04:15:54 PM »
For the Base-USA distribution, I've now removed WU-radar-inc.php, WU-radar-testpage.php from the distribution, changed flyout-menu.xml to remove the link, and changed wxradar.php to handle missing WU-radar-inc.php gracefully.
It has been a long-running script (first released by Tom of Carterlake 07-Jan-2008) and has been adapted over the years as WeatherUnderground tweaked with their website design.  Now it's time to say goodbye -- they apparently want to focus exclusively on the WunderMap for radar display and that's not really adaptable to our scripting for personal weather websites.
« Reply #6 on: August 16, 2022, 10:34:51 PM »
that stinks
also no more data will be sent to WU.
« Last Edit: August 16, 2022, 10:44:14 PM by chief-david »
Offline 92merc
  • BismarckWeather.net
« Reply #7 on: August 17, 2022, 08:54:41 AM »
« Reply #8 on: August 17, 2022, 10:17:14 AM »
yeah, I am going to do some dinking around today.
Was there also a new goes 18 set up that I should install?
Offline 92merc
« Reply #9 on: August 17, 2022, 10:26:33 AM »
Doesn't look like you have that package added to your site.  So you don't have to.  But you could add it.  It isn't so much a radar image collection as it is a satellite image suite.  A couple of the infrared images are precip at different altitudes.  But not quite the same as the radar.
I just switched mine from the package that uses the GIF images, to the package that uses the latest JPG images.  Has more satellite views than just the GIF's.
https://www.bismarckweather.net/wxGOES16-HAniSLoopsTabbed.php
« Reply #10 on: August 17, 2022, 10:47:45 AM »
where is that goes 18 package? Time to update
Offline 92merc
« Reply #11 on: August 17, 2022, 10:50:13 AM »
If you look at my page, I'm running the "tabbed" version.  Which means you see both the GOES18 and GOES16 satellites at the top.  I just default to the GOES16 since that's our region.  GOES18 is the west coast system.
« Reply #12 on: August 17, 2022, 10:53:14 AM »
Ok. I am going to work on changes today.
Damn WU. If I cant use their stuff, I am done sending data.
Offline gwwilk
  • Southeast Lincoln Weather
« Reply #13 on: August 17, 2022, 07:01:03 PM »
You can find this package on my scripts page.  It does take some savvy to get it installed, but you should be just fine!
Regards, Jerry Wilkins
gwwilk@gmail.com
« Reply #14 on: August 17, 2022, 10:53:39 PM »
Great.T hanks
Will play around tomorrow night.
Offline rormeister
« Reply #15 on: August 18, 2022, 01:47:23 PM »
Would this suffice?
https://radar.weather.gov/ridge/lite/KMPX_loop.gif
I could definitely integrate that, however, I'm at a loss to find the proper "KMPX" code for Seattle. Any hints?
Offline sam2004gp
  • Mount Crawford, Virginia
  • Weeeeeeeee!!!!
    • Mount Crawford Weather, VA
« Reply #16 on: August 18, 2022, 02:17:01 PM »
Would this suffice?
I found Seattle....
https://radar.weather.gov/ridge/lite/KATX_loop.gif
but still in search of something that puts my small town of Mount Crawford, VA in the center of the map. #-o
« Last Edit: August 18, 2022, 02:20:11 PM by sam2004gp »
« Reply #17 on: August 18, 2022, 03:26:13 PM »
I found Seattle....
Try using https://radar.weather.gov/ridge/lite/KLWX_loop.gif
Offline rormeister
« Reply #18 on: August 18, 2022, 03:29:02 PM »
I found Seattle....
Pure Genius!  Thanks, that will do nicely. BuhBye WU
Offline sam2004gp
  • Weeeeeeeee!!!!
« Reply #19 on: August 18, 2022, 03:44:46 PM »
I found Seattle....
I did see that in my search for Seattle.  But I was looking for something that was not as broad, perhaps just one county or so around me.
But thanks for the help.
« Reply #20 on: August 18, 2022, 04:10:27 PM »
And I am out.....school, home. Bye WU
« Reply #21 on: August 18, 2022, 07:00:45 PM »
Would this suffice?
Far superior radar display here AFAIC. You can zoom and move the image as well. Unfortunately, you're a long ways from all the sites, so your resolution isn't the best.
https://weather.cod.edu/satrad/nexrad/?parms=FCX-N0Q-1-24-100-usa-rad
Offline weatherdoc
« Reply #22 on: August 19, 2022, 07:44:51 AM »
While it's not free ($79.95 for a lifetime license), there's always GRLlevel3 software (http://grlevelx.com/grlevel3_2/). It's highly customizable giving you full control of what and how you display on your website. I run two instances of GRLlevel3 to produce what I call a regional view (https://novawx.dscloud.me/wxradar-refl.php) and then a local (zoomed in) view (https://novawx.dscloud.me/wxgr3-refl.php). I still use WU for a broad mosaic view (https://novawx.dscloud.me/wxradarmosaic-wu-ma.php).
