Author Topic: (meteobridge) posting to Meteotemplate: port 443: Connection timed out" SOLVED  (Read 653 times)
Offline alexvanuxem
hi,
on my meteotemplate site, data loaded via meteobridge and the mt network plugin: I added a ecowitt gw1100 lihtning detector.
Trying to custom upload the data.
Had to write a .htaccess file to redirect from https to http.
Data seems to go through, but in the cache/ecowittlog.txt file it says : port 443: Connection timed out
when trying to access the api file.
What does this mean and how to resolve it?
Many thanks
« Last Edit: June 10, 2022, 01:10:29 PM by alexvanuxem »
Offline Rover1822
Re: port 443: Connection timed out
« Reply #1 on: June 09, 2022, 01:25:46 PM »
If going to 443 on ecowitt.net , if that is what you are doing, I don't believe that will work. Needs to be 80.
As you appear to be familiar with Apache , you can proxy it and change the port to 80, if it is coming in HTTPS and you are going to HTTP.
« Last Edit: June 09, 2022, 01:27:54 PM by Rover1822 »
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Online Gyvate
« Reply #2 on: June 09, 2022, 02:42:27 PM »
hi,
Many thanks
I think your answer lies in the post
https://www.wxforum.net/index.php?topic=40447.0
where you already asked similar questions regarding your air quality sensors
and specifically for the lightning sensor
you have already posted the same/similar question in the Meteobridge forum - there is also a respective post - needs some digging
there are two ways to go - via http-ecowitt gateway or standard Meteotemplate API - both work (I use MB via MT API only)
but you have to choose the proper variables which you send with the Meteotemplate markers: e.g. L=[lgtx!0total-dmax.0:], LD=lgtx!0dist-lastval.1:], LT=[lgtx!0total-nonzerotime=EPOCH]
 (x: your station number in Meteobridge. ) remember: variable: sensor-selector=conversion.decimal:replacement (see Meteobridge WiKi - section templates)
For "L" (number of strikes per day, increasing like rain) a database column already exists, for LD (distance) and LT (last lightning time stamp) columns might need to be created in the database.
But even without a database field existing, the markers will arrive in the API and will be available there - only not archived.
not sure what you mean by "MT network plugin" ...
normally MB posts to MT are http posts (no https) - of course if your server in the web doesn't accept http posts, you'll have to sort this out with your hosting provider
Online Gyvate
« Reply #3 on: June 09, 2022, 02:51:31 PM »
your http request in Meteobridge for the Meteobridge API string should be:
http://your-domain/your-path-from-www-root/template/api.php?U=[epoch.1:]&....&L=[lgt0!0total-dmax.0:]&LD=[lgt0!0dist-lastval.0:]&LT=[lgt0!0total-nonzerotime=epoch:]&PP1=[air0!0pm-lastval.2:]&PP2=[air0!1pm-lastval.2:]&PP3=[air0!4pm-lastval.2:]&PP4=[air0!5-lastval.2:]&....&PASS=your-password
the numbers in front of the "!" will depend on the station number your sensors belong to. Primary station=0, Station 1 = 1 etc.
The above example is for station 0 (primary).
The ... are for additional sensors you may have or may not have - make sure there is only one "&" between a "]" and the next marker (e.g. "L")
« Last Edit: June 09, 2022, 03:02:14 PM by Gyvate »
Offline Rover1822
« Reply #4 on: June 09, 2022, 02:57:29 PM »
I defer to Gyvate, I just saw you making changes to .htaccess , a Apache webserver specific file . (I work a lot with various webservers, so a light went off, when I saw the 443 error)
I really don't know anything else as far as Meteobridge.
So in essence, go with whatever Gyvate suggests.
-Rover
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Online Gyvate
« Reply #5 on: June 09, 2022, 03:02:42 PM »
one (or two) more thing(s):
if selector "lastval" doesn't work, try "avg"
I suggest you first create an export event in Meteobridge with the API string and check if the results are what you expected - once they fit, create the http post
Offline alexvanuxem
« Reply #6 on: June 10, 2022, 07:49:45 AM »
sorry for the confusion.
I use meteobridge, In the tab 'networks' , I selected the 'plugin' Metetemplate, where I only need to enter the website name and my update pasword. No http request, this is the easy way, cron job included.
For the lightning sensor of ecowitt: there's a ecowitt plugin that allows custom upload, even if you use my way.
if I pass https://www.sint-katelijne-waver-meteo.be/template/api.php?U=1654861129&PASS=MYPASSWORD&P=1023.79&TIN=25.28&HIN=50&L=0&LD=&LT=&LBAT=3&Station=GW1100A&FW=V2.0.2
it gets through without a problem, and the api is updated with the lightning,
but for a reason I dont  know, and yes im asking different people, just to  get an answer, the ecowittlog gives a 443 error.
so ecowitt plugin in meteotemplate gets the data from my gw1100, and wants to update the api.php file.
and there's something wrong, I guess with at my providers end? I also asked them for an explanation.
ps: i tried also to add the gw1100 as an extra station inside meteobridge, but no lightning data gets through. I have seen posts here that explain way, its a meteobridge issue, from what I have read.
thx for helping.
Online Gyvate
« Reply #7 on: June 10, 2022, 08:06:03 AM »
you can do it the easy way = the way it works  8-) - see my API string as http request
or you can do it your way
dealing with the incomplete posting of the standard MB posting to MT - and the ecowitt-http-plugin
and potential issues
@davidefa is an experienced user for the ecowitt-http plugin, the lightning plugin etc. with Meteotemplate
if he doesn't react by himself on this post after some time - ping him with a PM
it also depends on what you want to do with the lightning data ...
you need to know what you (want to) do and what Meteobridge standard does - it only sends the data from the primary station.
If you add the GW1x00 as station1, 2 ... the standard won't send its data - that's why you need a custom string and a custom http request with the sensors of your GW1x00 station in it, e.g. lgt1!0total if you added your GW1100 as station 1 - if it's station 2, the sensor is lgt2!0total (for the # of lightnings) the whole variable will be, as mentioned before, [lgtx!0total-dmax.0:] x= station number
You can also have the GW1x00 post via its custom server function (and use ecowitt-http-plugin), which is at the end of the also just another http request posted by the console custom server functionality instead of having MB do the post
of course, sending this string will transfer L=0 and you will find a "0" for your time stamp in the MT API. The question is how to make MB create this value behind "L=" - and post it.
The answer is: L=[lgtx!0total-dmax.0:]  where x= station number
Maybe you care to amend your original posting subject like " (meteobridge) posting to Meteotemplate: port 443: Connection timed out" for better understanding of the other forum users paging through the list of threads
(you have to do this in the very first post)
« Last Edit: June 10, 2022, 08:27:00 AM by Gyvate »
Offline alexvanuxem
thank you for reply.
Learned a lot from your last answer.
Got a reply from Davidefa: 'Please try this updated plugin ( it simply replaces the call to api.php via 'curl library', that fails with a timeout on your server, with a 'require', that should work in your case )'.
And it works.Many thanks to Davidefa.
Learning day by day,
Thank you for patience with me.
