Author Topic: What is the difference between WH31, WH32 Ind WH32 Out  (Read 321 times)
Offline Aircub
    • Twinfirs Broadstone
« on: June 04, 2022, 05:26:04 AM »
Can someone tell me the difference between these
Offline olicat
    • FOSHKplugin
Re: What is the difference between WH31, WH32 Ind WH32 Out
« Reply #1 on: June 04, 2022, 06:44:54 AM »
Hi!
The WH31 is an 8-channel T/H sensor whose values are recognised and output by the console as additional sensors.
The WH32 outdoor is a T/H sensor that is processed by the console as an outdoor sensor. There can only be ONE of these per console. It overrides any existing T/H sensor of any combi-sensor.
The WH32 indoor is the T/H/P sensor for the WH2650, HP350xC and HP255xC consoles and provides the indoor temperature and humidity in addition to the air pressure. These values are then displayed and output by the console as indoor values. Only exactly ONE unit of this sensor can be used per console.
Oliver
Offline Aircub
« Reply #2 on: June 04, 2022, 06:46:24 AM »
Great many thanks for the clear explanations. I have purchased 2 WH31 to act as Temp sensors for my outside sheds.
Offline box
« Reply #3 on: June 04, 2022, 06:49:13 AM »
I did the same for our polytunnel and greenhouse, worked perfectly
