in the right box the text of/for only two out of expected six appear. It would be nice if the six piezo items also appeared in clear text with their values in the interface window.
interestingly gw1000.txt seems to contain the piezo rain data whereas gw1000rain.txt contains only the traditional rain data.
Just wondering why you named the files just the opposite way. For the result it doesn't matter.
findings:
traditional rain should be
expected found
(14)0x0E//Rain Rate (mm/h) 2 0.00 0.00
(16)0x10//Rain Day (mm) 2 0.00 0.00
(17)0x11//Rain Week (mm) 4 12.2 12.2 (size 2 in LIVEDATA, 4 in READ_RAIN)
(18)0x12//Rain Month (mm) 4 87.6 87.6
(19)0x13//Rain Year (mm) 4 308.5 308.5
(13)0x0D//Rain Event (mm) 2 0.00 0.00
(15)0x0F//Rain Gain 2 1.00 1.00
this shows in gw1000rain.txt and gw1000.txt
piezo should be expected found (in gw1000.txt)
(128)Piezo_Rain_Rate 0x80// 2 0.0 0.0
(129)Piezo_Event_Rain 0x81// 2 0.0 0.0
(130)Piezo_Hourly_Rain 0x82// 2 reserved, not used --- doesn't occur (expected)
(131)Piezo_Daily_Rain 0x83// 4 0.0 0.0
(132)Piezo_Weekly_Rain 0x84// 4 11.3 11.3
(133)Piezo_Monthly_Rain 0x85// 4 59.1 59.1
(134)Piezo_yearly_Rain 0x86// 4 317.1 317.1
(135)Piezo_Gain10 0x87// 2*10 10 * 1.00 10 * 1.00
(136)RST_RainTime 0x88// 3 (not applicable in this context)
the correct data for the CMD_READ_RAIN has been retrieved and is contained in gw1000.txt
Luckily I had started it standalone in a directory different from \wdisplay - it would have messed up my data due to the inverse naming
